[Geomoose-users] [Geomoose for beginner's
Robert R. Raiz raizrobert at gmail.com
Mon Sep 2 00:53:34 PDT 2013
Oh, I've sent the email too soon. You have to get rid of the coma (",")
from the extent. Leave the extent values separated only by a space and do
not put commas. Like this:
<param
name="initial_extent">22.7357449240 -30.0018000880 30.1947199310
34.2138600920</param>
On Fri, Aug 30, 2013 at 11:23 PM, Brian Fischer <bfischer at houstoneng.com>wrote:
>  These parameters don’t look right.****
>                                 <param
> name="max_extent">-20037508.342789,-20037508.342789,20037508.342789,20037508.342789</param>
> (I think this needs to match your initial extent)****
>                                 <param
> name="initial_extent">25.916250,-32.592279 25.937444,-32.580086</param>***
> What projection did you put your parcel shapefile in?  The way you have
> your mapfile setup it would have to be in EPSG 4148. ****
> *Brian Fischer*
> Principal | GIS Project Manager ****
> Houston Engineering, Inc.****
> *O* 763.493.4522 | *D* 763.493.6664 | *F* 763.493.5572****
> *From:* geomoose-users-bounces at lists.osgeo.org [mailto:
> geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Solly Vuso
> *Sent:* Friday, August 30, 2013 2:16 PM
> *To:* James Klassen
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] [Geomoose for beginner's****
> Thank you for assisting me****
> I have one small problem, I don't know which part I have missed ****
> 1.I have edited Mapfile for parcels , the extent and the projection (I
> have created my own shapefile and rename it parcels)****
> 2. I have changed also the Mapbook.xml (I added EPSG in that list and also
> changed the extent of parcels under Jump to)****
> 3. I have replaced the parcels shapefile with my own shapefile but using
> the same name****
> The only problem I get on the browser is blank where it suppose to be a map
> I have attached the mapbook.xml and parcels.mapfile****
> On Tue, Aug 27, 2013 at 6:12 PM, James Klassen <klassen.js at gmail.com>
> wrote:****
> conf/mapbook.xml is the default mapbook and is the one that will take
> effect unless you have done something special.
> I am not sure what mapbook.txt is.  You can ignore mapbook_dev.xml as it
> is an artifact from GeoMoose 2.4 or older and is no longer used.
> I am not sure what you mean by "change the coordinates of parcel data".
> If you mean changing projections:  There are two places projections are in
> play.
> 1) MapServer needs to   know what projection your data is in.  This is set
> in the MAP->LAYER->PROJECTION in the mapfile.
> http://mapserver.org/mapfile/projection.html
> 2) GeoMoose needs to know what projection to display the data in.  All of
> your map-sources need to be able to render in the projection selected in
> GeoMoose.  In the demo this is EPSG:3857 so that the common tiled basemap
> layers work (Google, OSM, Bing, etc.)  If you are displaying in a
> projection other than EPSG:26915, EPSG:4326 EPSG:900913 or EPSG:3857 then
> you will need to add it to the list in MAP->WEB-METADATA->"ows_srs".
> This second case is covered here:
> http://docs.geomoose.org/2.6/docs/projections.html****
> On 2013/8/27 10:42 AM, Solly Vuso wrote:****
> Thank you Jim for replaying****
> When I open mapbook I see mapbook.xml and mapbook_dev and two mapbook.txt*
> Tell me if am wrong, I want to change the coordinates of parcel data in
> the mapfile and do the same also in mapbook.xml am not sure if I should
> also do the same in mapbook_dev****
> On 26 Aug 2013 5:07 PM, "James Klassen" <klassen.js at gmail.com> wrote:****
> Mapfiles tell MapServer how to access your data and draw your data as a
> map service.
> The Mapbook tells GeoMoose how to connect to layers in map services and
> how to make those layers available in the Catalog.  You will need to change
> the Mapbook to point to your new mapfile.
> http://docs.geomoose.org/2.6/docs/mapbook.html
> On 2013/8/26 9:40 AM, Solly Vuso wrote:****
> Hi Mark****
> Am new in geomoose, I would like to check when I want to use my own data
> wich file to change that will read the mapfile , I have already created a
> mapfile and name it parcels with my own data but I dont know what other
> file to twirk and make it to read my parcel mapfile .please help ****
> Thank you****
> On 26 Aug 2013 3:39 PM, "Mark Volz" <MarkVolz at co.lyon.mn.us> wrote:****
> Hello
> I noticed that everything on the bug tracker is closed and set to wontfix.
>  I am just curious as to what is going on.
> Thanks
> Mark Volz, GISP
> GIS Specialist
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users****
> _______________________________________________****
> Geomoose-users mailing list****
> Geomoose-users at lists.osgeo.org****
> Best Regards
> Solly Vuso
> Cell:073 3068 170
> Fax:086 555 1270
> I may not know what tomorrow holds for me but I do know who holds ma
> tomorrow..... ****
*Raiz Roland Robert*
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130902/20567791/attachment-0001.html>
More information about the Geomoose-users mailing list
