[Geomoose-users] Selecting points with select features?
    TC Haddad
    tchaddad at gmail.com
    Sun Jan  5 17:36:17 PST 2014
If it's not correctly selecting using a box, then you probably have not set up your templates correctly. You need both a select and a results template configured for your layer, using field names from your layer.
On Jan 5, 2014, at 1:53 PM, Jason Menard <menard.jason at gmail.com> wrote:
> Hi TC,
> Yes, I'm doing a polygon select.  Clicking with a single point has never worked, even when I up the tolerances to unrealisitic levels.
> Best,
> Jason
> Jason Menard
> On Sun, Jan 5, 2014 at 3:47 PM, TC Haddad <tchaddad at gmail.com> wrote:
>> just a guess - are you selecting by drawing a box, or by single click point?
>> I would test with each mode in turn, because hitting a point with a single click is difficult (thus the tolerance settings..).
>> If drawing a select box is acceptable that might be the best path..
>> On Sun, Jan 5, 2014 at 1:34 PM, Jason Menard <menard.jason at gmail.com> wrote:
>>> Hi all,
>>> I'm trying to configure the buffered_select service to select points.  I have it working just fine with some parcel data, but it consistently gives me an "Error Calling the server:  Error: Unable to load php/select.php status:500"
>>> Clearly I am missing something obvious.  I've done the usual stuff, like increase the tolerance in the .map files and such, but it just won't work on these points.
>>> Any thoughts?
>>> Thanks very much!
>>> Best,
>>> Jason
>>> Jason Menard
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140105/4ce84cd9/attachment.html>
More information about the Geomoose-users
