[Geomoose-users] install of GM on localhost
Mark Volz MarkVolz at co.lyon.mn.us
Mon Jan 13 14:33:50 PST 2014
Jim,
It has been a while since I worked on GeoMOOSE and IIS.  But to start here are a couple things I might check out:
*         GeoMOOSE 1.6 is old.  It is not compatible with the newer versions of MS4W.  If needed I can see if I can find the link that is compatible with GeoMOOSE 1.6.
*         GeoMOOSE 1.6 is old.  This may be a good excuse to upgrade
*         There may be some settings in your mapfiles and application files that have been added to connect to the IIS version of PHP.  I think I still have GM 1.6 /IIS code somewhere around.  I will see if I can find anything.
*         It may help to download the GM 1.6 demo (if it is still out there) to see if there are any IIS vs Apache changes?
*         In apache you need to configure the httpd.conf file in C:\ms4w\httpd.d.  If you're using the defaults then you might not need to do anything here.
Mark Volz, GISP
GIS Specialist
Lyon County, MN
(507) 532-8218
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Jim Dahl
Sent: Monday, January 13, 2014 4:05 PM
To: 'geomoose-users at lists.osgeo.org'
Subject: [Geomoose-users] install of GM on localhost
I downloaded the MS4W from Maptools and the GM 1.6 from Geomoose.org and started Apache.  I can get the skins to show but not the data for the Countydemo.  Anything I might be forgetting?
What I really want to do is migrate my current IIS GM from the server to my desktop running Apache.  When I move the folders to my own computer it breaks everything on the GM interface.  I am installing on local hard drive named A:\
Thanks, Jim
PLEASE NOTE:
Douglas County e-mail addresses have changed.
Addresses no longer contain the full name of the employee and the last part of the e-mail address is now: @co.douglas.mn.us.
Please update your contact information for Douglas County employees.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140113/649668f3/attachment.html>
More information about the Geomoose-users mailing list
