[Geomoose-users] Asking technical problem regarding displaying shape file
Brent Fraser
bfraser at geoanalytic.com
Thu May 8 06:33:03 PDT 2014
Amila,
Please make sure you reply to the Geomoose list as well so others can
benefit.
Use Mapserver's shp2imge command line program to track down problems
with your map file.; it is included with MS4W. It will show error
messages for problems it finds (also look in mapserver's error log).
You can use GDAL's ogrinfo command to check the PostGIS database connection.
The most common reason for data not displaying is an error in
specifying the coordinate systems. Below is a guess, since I don't know
the details of your PostGIS table (have a look at
http://mapserver.org/input/vector/postgis.html):
# Use X Y X Y:
EXTENT 456029 801937 467996 808358
LAYER
NAME 'kysitesutmrd1'
STATUS ON
TYPE POINT
# ---- Same As EPSG:4326 in DATA object below ----
PROJECTION
"+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
END
CONNECTIONTYPE postgis
CONNECTION 'host=localhost dbname=postgis_21_sample
user=postgres password=postgres port=5432'
DATA 'wkb_geometry from kysitesutmrd using unique gid using
srid=4326'
CLASS
#NAME 'KYsites'
# --- Should use STYLE object instead: ---
COLOR 254 0 0
SYMBOL "star"
SIZE 8
END# CLASS
END # LAYER
Best Regards,
Brent Fraser
On 5/7/2014 11:01 PM, Amila Karunathilake wrote:
> Dear sir,
> Thank you very much for your quick reply for my problem.
> Sir, I have incorporate changes you have mention,
> 1. EXTENT 8887274.859924 787036.529767 9096903.423788 852344.927174
> 2. PROCESSING "CLOSE_CONNECTION=DEFER"
> Now, pink color display not appearing any more but points(.shp) were
> not displaying...?
> Sir, Previously i directly stored data (.shp, .tiff..) in countydata
> folder (C:\ms4w\apps\thilankamaps\maps\demo\countydata).
> Then all the shp's were nicely displayed.
> But lastweek this problem occurs while i try to connect my geomoose
> application to
> the postgis databases.
> Herewith i attached my old shp + map files (KYsitesUTM and msitesTW)
> which properly work with geomoose (mapserver)
> But problem is why new map file with database connectivity codes, not
> display properly....?
> Sir, your kind help is highly appreciated, because in Srilanka we do
> not have any web GIS
> specialist in the field.
> Thank you again for you consideration.
> Amila.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140508/7e46f73b/attachment.html>
More information about the Geomoose-users
