[Geomoose-users] TinyOWS question.
Brent Fraser bfraser at geoanalytic.com
Wed Sep 3 15:28:11 PDT 2014
Bobb,
It has been some time since I tried to integrate GeoMoose v2.6 editing
with TinyOWS (2.5 years? really?). The two main problems I ran into were:
1. No inserts allowed by TinyOWS, only edit and delete (a bug; I'll look
up the version.  hopefully fixed by now)
2. No display in one projection and store in another (a GeoMoose fix
required, I think)
and of course difficulty setting up the config files because of
terminology/name-space mapping between:
     - PostGIS (btw, only PostGIS supported by TinyOWS still?) ,
     - TinyOWS XML
     - OpenLayers API
     - GeoMoose Mapbook
I've attached the doc I had made (basically an edit of Dan's GeoServer
doc), but no guarantee they are still valid (or ever were).
Best Regards,
Brent Fraser
On 9/3/2014 11:46 AM, Basques, Bob (CI-StPaul) wrote:
> All (and I'm told, specifically Brent . . .)
> We need a working example of a Mapfile for connecting to TinyOWS for
> editing from GeoMOOSE.
> TinyOWS is throwing Schema errors on edit.
> Thanks
> Bobb
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140903/204b5594/attachment.html>
Using TinyOWS with GeoMOOSE
This is a basic walk-through of adding vector editing to a GeoMOOSE site using the WFS-T server TinyOWS and PostGIS (currently TinyOWS works only with PostGIS).  This is not meant to be comprehensive and the reader should have some knowledge of PostGIS.
Install TinyOWS
The best documentation on setting up TinyOWS comes from the TinyOWS project itself `TinyOWS Documentation <http://mapserver.org/trunk/tinyows/>`_.
An easy way to install and startup a fresh TinyOWS instance is to use the TinyOWS distribution on the MS4W site `TinyOWS Download <http://www.maptools.org/ms4w/index.phtml?page=downloads.html>`_.
Download the Places Layer from the Census Bureau
We'll be using the standard Geomoose demo and enhancing it by adding a "Census Cities" layer of places.  First, we need some data.
Download the file `here <ftp://anonymous@ftp2.census.gov/geo/tiger/TIGER2010/PLACE/2010/tl_2010_27_place10.zip>`_.  This is the "place" file for the state of Minnesota.  "Places" are a Census terminology for incorporated cities, townships, and equivalents.
Install the Places Shapefile into PostGIS
Create a new database in PostGIS called gis2 using template:template_postgis and Encoding:UTF8.
There are a few good methods for doing this, for example the command line tools `ogr2ogr` or `shp2pgsql`.   Whichever method is used, the layer should be named `census_cities` for the purposes of this example.
**TBD: use shp2pgsql
shp2pgsql -c -s 4269 tl_2010_27_place10.shp > census_cities.sql
psql -U postgres -d gis2 -f census_cities.sql
A typical `ogr2ogr` string will look similar to this::
	ogr2ogr -f PostgreSQL PG:"dbname=gis2 user=gis password=super_gis" tl_2010_27_place10.shp tl_2010_27_place10 -nln census_cities -nlt MULTIPOLYGON -lco DIM=2
Configure TinyOWS
Edit the TinyOWS config.xml
Edit the C:\ms4w\apps\tinyows\config.xml
  <tinyows online_resource="http://127.0.0.1/cgi-bin/tinyows.exe"
    schema_dir="/ms4w/apps/tinyows/schema/"
    log="/ms4w/tmp/tinyows.log"
    log_level="15">
    <pg host="127.0.0.1" user="postgres" password="postgres" dbname="gis2" port="5432"/>
    <metadata name="TinyOWS Server" title="TinyOWS Server - Demo Service" />
    <layer retrievable="1"
	  writable="1"
	  ns_prefix="gis2"
	  ns_uri="http://127.0.0.1/cgi-bin/tinyows.exe"
	  name="censuscities"
	  srid="4269"
	  title="Census Cities" />
  </tinyows>
Note the 127.0.0.1 in the ns_uri should be changed to the name of your server.
Check the config
  set TINYOWS_CONFIG_FILE=/ms4w/apps/tinyows/config.xml
  C:\ms4w\apache\cgi-bin\tinyows --check
  NOTICE:  Function postgis_topology_scripts_installed() not found. Is topology support enabled and topology.sql installed?
  TinyOWS version:   1.0.0rc3
  FCGI support:      Yes
  Config File Path:  /ms4w/apps/tinyows/config.xml (TinyOWS XML)
  PostGIS Version:   2.0.1
  PostGIS dsn:       host=127.0.0.1 user=gis password=super_gis dbname=gis2 port=5432
  Output Encoding:   UTF-8
  Database Encoding: UTF8
  Schema dir:        /ms4w/apps/tinyows/schema/
  Display bbox:      Yes
  Estimated extent:  No
  Check schema:      Yes
  Check valid geoms: Yes
  Available layers:
   - public.census_cities (4269) -> gis2.census_cities [RW]
Restart the TinyOWS service
GeoMoose Setup
Edit the geommose.html
Add a reference to the data's SRS into the geommose.html::
	<script type="text/javascript" src="projections/EPSG4269.js"></script>
If it is not already there, you need to add the EPSG4269.js file to the projections folder. The file contains:
	Proj4js.defs["EPSG:4269"] = "+proj=longlat +ellps=GRS80 +datum=NAD83 +no_defs";
Mapbook Setup
The Mapbook currently features a fragment which supports the above configuration of TinyOWS. Here is that fragement::
	<map-source name="census_cities" type="wfs" status="on" srs="EPSG:4269">
		<style type="stylemap"><![CDATA[
			"strokeColor" : "#00ff00",
			"label" : "${name10}"
		]]></style>
		<url>/cgi-bin/tinyows.exe</url>
		<attribute name="name10" type="text" label="Name:"/>
		<attribute name="aland10"      type="text" label="Area:" default-value="0"/>
		<feature-namespace>http://127.0.0.1/cgi-bin/tinyows.exe</feature-namespace>
		<feature-type>censuscities</feature-type>
		<geometry-name>wkb_geometry</geometry-name>
		<schema><![CDATA[http://127.0.0.1/cgi-bin/tinyows.exe?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=censuscities]]></schema>
	</map-source>
Uncomment the layer in the catalog portion of the mapbook
More information about the Geomoose-users mailing list
