[Geomoose-users] Identify Tolerance
TC Haddad tchaddad at gmail.com
Fri Sep 5 11:58:17 PDT 2014
3 pixels is a pretty small target to hit with your mouse - you could try
something larger to confirm it really is not working.
Other things that sometimes prevent the Identify form working are: no
template specified, template with wrong name / path, template not
specifying the correct field names to report, etc.
On Fri, Sep 5, 2014 at 9:27 AM, Clinton Olsen <clintono at emery.utah.gov>
wrote:
> I used a ESRI program to reproject the layer to web mercator, so Geomoose
> isn't doing any reprojecting.
> I took the advice to set my TOLERANCE to 3 and the TOLERANCEUNITS to
> pixels and I still don't have any result other than the coordinates.
> I ran Geomoose through the Internet Explorer F12 network tool and when I
> try an identify it seems to send its data through
> /geomoose2/php/idenitfy.php, with a POST method and 200 for the Result.
> Thanks for the suggestions so far.  Any other ideas as to what I could try?
> LAYER
>         NAME "boulders"
>         DATA "boulders.shp"
>         STATUS DEFAULT
>         TYPE POINT
>         METADATA
> # drill-down identify service record.
>      'identify_record' 'identify_boulders.html'
> END
>         TOLERANCE 3
>         TOLERANCEUNITS pixels
>        LABELITEM 'BOULDER'
>         LABELCACHE ON
>         LABELMAXSCALE 100000
>          CLASS
>               NAME 'Boulders'
>         STYLE
>            SYMBOL 'CIRCLE'
> COLOR 255 102 51
> OUTLINECOLOR 0 0 0
>              SIZE 8
>          END
>   LABEL
>       TYPE TRUETYPE
>       FONT vera_sans-bold
>       SIZE 8
>       ANTIALIAS TRUE
>      COLOR 0 0 0
>       OUTLINECOLOR 254 254 254
>       BUFFER 4
>       PARTIALS FALSE
>       POSITION auto
> SIZE 7
>    END #end label
>      END#end class
> END#end layer
> END #end map
> On Wed, Sep 3, 2014 at 10:47 AM, Anderson, Dean <
> anderson.dean at co.polk.or.us> wrote:
>> That sounds better to me. Especially when you have different projections.
>> On Wed, Sep 3, 2014 at 9:21 AM, Brent Fraser <bfraser at geoanalytic.com>
>> wrote:
>>>  Clinton,
>>> I like using
>>>         TOLERANCE 3
>>>         TOLERANCEUNITS PIXELS
>>> to make it more "zoom friendly".
>>> And you can use the debugging tool (F12, Network tab, Response sub-tab)
>>> on your browser to view the conversation between browser and the server.
>>> Best Regards,
>>> Brent Fraser
>>> On 9/3/2014 9:20 AM, Clinton Olsen wrote:
>>> Dean,
>>>  I adjusted my map file according to your suggestions and I still am
>>> not retrieving any information from the point layer.  I don't know if this
>>> will help but I have all of my layers reprojected to the web mercator
>>> projection (EPSG:3857).  Is there a way to see if anything is being passed
>>> when I try to identify an object?  Below is my mapfile with the suggested
>>> changes.
>>>  LAYER
>>> NAME "boulders"
>>> DATA "boulders.shp"
>>> STATUS DEFAULT
>>> TYPE POINT
>>>  METADATA
>>>  END
>>> TOLERANCE 100
>>> TOLERANCEUNITS meters
>>> LABELITEM 'BOULDER'
>>> LABELCACHE ON
>>>  CLASS
>>>               NAME 'Boulders'
>>>   STYLE
>>>          SYMBOL 'CIRCLE'
>>>  COLOR 255 102 51
>>>  OUTLINECOLOR 0 0 0
>>>            SIZE 8
>>>             END
>>>   LABEL
>>>  TYPE        TRUETYPE
>>>       FONT vera_sans-bold
>>>        SIZE 8
>>>        ANTIALIAS TRUE
>>>        COLOR 0 0 0
>>>        BUFFER 4
>>>        PARTIALS FALSE
>>>        POSITION auto
>>>        SIZE 7
>>>  END #end label
>>>   END#end class
>>> On Fri, Aug 29, 2014 at 4:15 PM, Anderson, Dean <
>>>> Here is what I use to identify roads and the tolerances seems to work
>>>> fine.  (TOLERANCE 100
>>>>   TOLERANCEUNITS FEET)  as follows:
>>>>  Layer  #14
>>>>   Name "Roads"
>>>>   Data './data/RoadAllWeb'
>>>>   Status On
>>>>   Type Line
>>>>   METADATA
>>>>   'identify_record' 'templates/identify_road.html'
>>>>   END
>>>>   TOLERANCE 100
>>>>   TOLERANCEUNITS FEET
>>>>   ClassItem "RoadType"
>>>> Class
>>>>    Name "Major Roads"
>>>>    minscale 40001
>>>>    maxscale 100000
>>>>    EXPRESSION "Major Roads"
>>>>  STYLE
>>>>  Width 4
>>>>  COLOR 168 112 0
>>>>  END
>>>>  STYLE
>>>>  width 2
>>>>  COLOR 255 211 127
>>>>  END
>>>>   End
>>>>   Class
>>>>    Name "Major Roads"
>>>>    maxscale 40000
>>>>    Minscale 10001
>>>>  STYLE
>>>>  width 4
>>>>  COLOR 168 112 0
>>>>  END
>>>>  STYLE
>>>>  width 2
>>>>  COLOR 255 211 127
>>>>  END
>>>>   End
>>>>   Class
>>>>    Name "Major Roads"
>>>>    maxscale 10000
>>>>  STYLE
>>>>  width 6
>>>>  COLOR 168 112 0
>>>>  END
>>>>  STYLE
>>>>  width 3
>>>>  COLOR 255 211 127
>>>>  END
>>>>   End
>>>>   Class
>>>>    Name "Standard Roads"
>>>>     EXPRESSION "Local Roads"
>>>>    minscale 40001
>>>>    maxscale 100000
>>>>  STYLE
>>>>  width 2
>>>>  COLOR 160 160 160
>>>>  END
>>>>  STYLE
>>>>  width 1
>>>>  COLOR 204 204 204
>>>>  END
>>>>   End
>>>>   Class
>>>>    maxscale 40000
>>>>    minscale 10001
>>>>  STYLE
>>>>  width 4
>>>>  COLOR 160 160 160
>>>>  END
>>>>  STYLE
>>>>  width 2
>>>>  COLOR 204 204 204
>>>>  END
>>>>   End
>>>>   Class
>>>>    maxscale 10000
>>>>  STYLE
>>>>  width 6
>>>>  COLOR 160 160 160
>>>>  END
>>>>  STYLE
>>>>  width 3
>>>>  COLOR 204 204 204
>>>>  END
>>>>   End
>>>> End
>>>>  On Fri, Aug 29, 2014 at 1:44 PM, Clinton Olsen <
>>>> clintono at emery.utah.gov> wrote:
>>>>>   When I try to identify a line or a point I get coordinates on the
>>>>> left side of the template.  Is there a way to troubleshoot the identify
>>>>> tool?  I know I might not have the tolerance set right but how can I figure
>>>>> out what the tolerance should be.  I have tolerance numbers I have used
>>>>> range from 0 - 100.  I have tried meters, feet, pixels.  I referenced the
>>>>> how to setup identify on the geomoose.org site and I got one of my
>>>>> polygon layers to work.  My template and mapfile are listed below.  How can
>>>>> I troubleshoot what is wrong with these files?
>>>>>  <!-- MapServer Template -->
>>>>> <tr><td colspan="2"><b>Boulder Areas</b></td></tr>
>>>>>  <tr><td>Boulder Area: [SECTION]</td></tr>
>>>>>  <tr><td>Boulder: [BOULDER]</td></tr>
>>>>>  <tr><td>LAT: [LAT]</td></tr>
>>>>>  <tr><td>LONG: [LONG]</td></tr>
>>>>>  <tr><hr></td></tr>
>>>>>  MAP
>>>>>  NAME 'BOULDERS'
>>>>>  SIZE 800 650
>>>>>  STATUS ON
>>>>>  EXTENT  -12381838.298411 4760938.642311 -12327375.283263
>>>>> 4806362.074758
>>>>>  UNITS METERS
>>>>>  INCLUDE "../../geomoose_globals.map"
>>>>>  WEB
>>>>>  METADATA
>>>>>  'ows_title' 'Boulders'
>>>>>  'ows_srs' 'EPSG:3857'
>>>>>  'ows_enable_request' '*'
>>>>>  'ows_onlineresource' 'http://www.geomoose.org'
>>>>>  END
>>>>>  END
>>>>>  PROJECTION
>>>>>  'init=EPSG:3857'
>>>>>  END
>>>>>  LEGEND
>>>>>       STATUS ON
>>>>>       LABEL
>>>>>  TYPE TRUETYPE
>>>>>  FONT vera_sans
>>>>>  SIZE 8
>>>>>  COLOR 0 0 0
>>>>>       END
>>>>>  END
>>>>>  LAYER
>>>>>         NAME "boulders"
>>>>>         DATA "boulders.shp"
>>>>>          STATUS DEFAULT
>>>>>         TYPE POINT
>>>>>         TOLERANCE 0
>>>>>           LABELITEM 'BOULDER'
>>>>>         LABELCACHE ON
>>>>>             CLASS
>>>>>               NAME 'Boulders'
>>>>>            STYLE
>>>>>                SYMBOL 'CIRCLE'
>>>>>  COLOR 255 102 51
>>>>>  OUTLINECOLOR 0 0 0
>>>>>              SIZE 8
>>>>>                   END
>>>>>   LABEL
>>>>>          TYPE TRUETYPE
>>>>>          FONT vera_sans-bold
>>>>>          SIZE 8
>>>>>          ANTIALIAS TRUE
>>>>>          COLOR 0 0 0
>>>>>          BUFFER 4
>>>>>          PARTIALS FALSE
>>>>>          POSITION auto
>>>>>  SIZE 7
>>>>>          END
>>>>>         END
>>>>> METADATA
>>>>>  END
>>>>>  TOLERANCE 0
>>>>>  END
>>>>> END
>>>>>  Clinton Olsen
>>>>> IS/GIS Technician
>>>>>  _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>>> Dean R Anderson
>>>> IT Director
>>>> Polk County
>>>  *Please note my email address has changed to clintono at emery.utah.gov.
>>>  Please update your records.  Thanks.
>>>  Clinton Olsen
>>> *EMERY COUNTY*
>>> IS/GIS Technician
>>> 435-381-3592
>>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
>> Dean R Anderson
>> IT Director
>> Polk County
> Clinton Olsen
> *EMERY COUNTY*
> IS/GIS Technician
> 435-381-3592
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140905/bd935b02/attachment-0001.html>
More information about the Geomoose-users mailing list
