[Geomoose-users] Identify not working for non-MapServer WMS
Paul Wickman paul at flatrockgeo.com
Thu Sep 25 10:16:05 PDT 2014
I'm hitting a GeoServer v2.5.2 on the same machine, which does support GML
as an INFO_FORMAT for WMS GetFeatureInfo.  Here is a query that returns GML:
http://192.235.78.145/geoserver/arizona/wms?REQUEST=GetFeatureInfo&EXCEPTIONS=application%2Fvnd.ogc.se_xml&BBOX=-117.754932%2C28.443607%2C-106.103764%2C39.88997&SERVICE=WMS&INFO_FORMAT=application/vnd.ogc.gml&QUERY_LAYERS=arizona%3Aland_ownership&FEATURE_COUNT=50&Layers=arizona%3Aland_ownership&WIDTH=512&HEIGHT=503&format=image%2Fpng&styles=&srs=EPSG%3A4269&version=1.1.1&x=357&y=137
On Thu, Sep 25, 2014 at 11:44 AM, Dan Little <theduckylittle at gmail.com>
wrote:
> Double check the WMS service is returning valid GML.  Identify.php
> expects to get GML features back.
> On Thu, Sep 25, 2014 at 11:31 AM, Paul Wickman <paul at flatrockgeo.com>
> wrote:
> > Hello,
> > I have some GeoServer WMS layers setup in GM v2.6.  Displays fine but am
> not
> > getting any results back from the Identify tool.  Looking at the
> Javascript
> > log I see it dispatch a call to the identify.php service but nothing
> comes
> > back (I have not yet poked around identify.php).
> > Here is the <map-source> definition from the mapbook.xml
> >         <map-source name="land_ownership" type="wms" opacity="0.4"
> > tiled="true" queryable="true">
> >                 <url>http://192.235.78.145/geoserver/arizona/ows</url>
> >                 <layer name="land_ownership" />
> >                 <param name="STYLES" value="land_ownership" />
> >                 <param name="FORMAT" value="image/png"/>
> >                 <param name="TRANSPARENT" value="TRUE"/>
> >         </map-source>
> > And here is the URL were you can see it in action (or rather, inaction).
> > http://192.235.78.145/geomoose/geomoose.html
> > Thanks for any advice.
> > Paul Wickman
> > CTO | Flat Rock Geographics
> > 612.280.5850 | paul at flatrockgeo.com
> > www.flatrockgeo.com | twitter.com/flatrockgeo
> > Geomoose-users mailing list
> > Geomoose-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
Paul Wickman
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140925/d7faeb90/attachment.html>
More information about the Geomoose-users mailing list
