[Geomoose-users] Minor documentation fix
    James Klassen
    klassen.js at gmail.com
    Mon Sep 29 14:26:36 PDT 2014
Does catalog->layer->status still apply to 2.7?  I haven't used that in
ages.
It is a goal to not depend on a local MapServer, but it isn't tested often
(especially the PHP code).  I use GeoMoose with external WMS served by
MapServer, GeoServer and ESRI servers and the HTML/JS code should work
fairly well.  I tend to not use the PHP services as they haven't met my
deployment needs (threaded apache, etc.)
On Sep 29, 2014 3:57 PM, "Paul Wickman" <paul at flatrockgeo.com> wrote:
> One of these days I keep meaning to jump in and fix a few things on the
> documentation.  In the mean time, I thought I'd just go ahead and report
> this minor fix:
> The <map-source>
> <http://docs.geomoose.org/2.6/docs/mapbook.html#map-source> docs describe
> the optional *visibility *attribute for the <layer> child node.  Turns
> out this attribute should actually be called status (just like it is on the
> <layer> child node in the <catalog>).
> As I work more with non-MapServer WMS/WFS (most often GeoServer) I'll
> start compiling issues I come across and jump into things a bit more
> directly (probably after v2.8).
> Thanks
> Paul Wickman
> CTO | Flat Rock Geographics
> 612.280.5850 | paul at flatrockgeo.com
> www.flatrockgeo.com | twitter.com/flatrockgeo
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140929/a35bc780/attachment.html>
More information about the Geomoose-users
