[Geomoose-users] Minor documentation fix
Dan Little theduckylittle at gmail.com
Mon Sep 29 14:55:14 PDT 2014
There's no promises on popups.php.  That hasn't really been used or
maintained for a while.
On Mon, Sep 29, 2014 at 4:49 PM, Paul Wickman <paul at flatrockgeo.com> wrote:
> Thanks, Jim.  As I keep hitting GeoServer I'll report any issues to the
> correct place.  I'm already seeing a fix I need to make to the identify.php
> to addresses an issue I had reported to the mailing list the other day.
> Yes, I can see how the PHP services are more tightly bound to MapServer.  At
> this point the identify.php and popup.php services will fit my needs (after
> the fixes I'll be making).
> Have you written custom JS code to run WMS queries client-side rather than
> through the PHP services?
> -Paul
> On Mon, Sep 29, 2014 at 4:26 PM, James Klassen <klassen.js at gmail.com> wrote:
>> Does catalog->layer->status still apply to 2.7?  I haven't used that in
>> ages.
>> It is a goal to not depend on a local MapServer, but it isn't tested often
>> (especially the PHP code).  I use GeoMoose with external WMS served by
>> MapServer, GeoServer and ESRI servers and the HTML/JS code should work
>> fairly well.  I tend to not use the PHP services as they haven't met my
>> deployment needs (threaded apache, etc.)
>> On Sep 29, 2014 3:57 PM, "Paul Wickman" <paul at flatrockgeo.com> wrote:
>>> One of these days I keep meaning to jump in and fix a few things on the
>>> documentation.  In the mean time, I thought I'd just go ahead and report
>>> this minor fix:
>>> The <map-source> docs describe the optional visibility attribute for the
>>> <layer> child node.  Turns out this attribute should actually be called
>>> status (just like it is on the <layer> child node in the <catalog>).
>>> As I work more with non-MapServer WMS/WFS (most often GeoServer) I'll
>>> start compiling issues I come across and jump into things a bit more
>>> directly (probably after v2.8).
>>> Thanks
>>> Paul Wickman
>>> CTO | Flat Rock Geographics
>>> 612.280.5850 | paul at flatrockgeo.com
>>> www.flatrockgeo.com | twitter.com/flatrockgeo
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
> Paul Wickman
More information about the Geomoose-users mailing list
