[Geomoose-users] Change projection
    Brent Fraser
    bfraser at geoanalytic.com
    Tue Jan  6 07:57:20 PST 2015
Geograefin,
   I don't think 2.6 is very different with the way it handles
coordinate systems, but I will try it to make sure.
   Your web mapping site can have only one display coordinate system
(e.g. EPSG:3857, or EPSG:25833) at a time, but each of your local data
sets can be in any coordinate system.  Mapserver can re-project them to
the target display coordinate system if you give enough information in
your Mapserver map files.
   I used your estimates for the extents in the mapbook.xml
         <param name="max_extent">100000,1000000,999999,9999999</param>
         <param name="initial_extent">295743,5511505,709358,5755456</param>
Best Regards,
Brent Fraser
On 1/6/2015 8:03 AM, geo.graefin at web.de wrote:
> Dear Brant Fraser,
> thank you for your answer!
> I use GeoMOOSE 2.6. Does this make a difference?
> Cannot I use several coordinate systems (EPSG:25833 and EPSG:3857)?
> What have you entered as the max_extent in mapbook.xml?
> Sincerely, Geograefin
> *Gesendet:* Dienstag, 06. Januar 2015 um 15:11 Uhr
> *Von:* "Brent Fraser" <bfraser at geoanalytic.com>
> *An:* geo.graefin at web.de, geomoose-users at lists.osgeo.org
> *Betreff:* Re: [Geomoose-users] Change projection
> Geograephin,
>   I followed the instructions and got something reasonable:
> <deleted image>
> How can you tell your setup is not working properly?
> (Note that only the ArcGIS server will return tiles in the EPSG:25833
> coordinate system for the Background group).
> Best Regards,
> Brent Fraser
> On 1/6/2015 6:06 AM, geo.graefin at web.de wrote:
>     Hello,
>     here more in detail what I did:
>     1. I created a new js file including the declaration of the EPSG
>     code from spatialreference.org and deleted the one of EPSG:26915.
>     /Proj4js.defs["EPSG:25833"] = "+proj=utm +zone=33 +ellps=GRS80
>     +units=m +no_defs";/
>     2. I referenced this new js file in geomoose.html. Beside there is
>     another projection for the geographic coordinates (EPSG:3857). I
>     deleted the reference of EPSG:26915.
>     /<script type="text/javascript"
>     src="projections/EPSG3857.js"></script>
>     src="projections/EPSG25833.js"></script>/
>     3. I changed the parameters projection, max_extent and
>     initial_extent in mapbook.xml.
>     /<param name="projection">EPSG:25833</param>
>             <param name="zoomto"><![CDATA[
>                 "Zoom To:" : {
>                     "Sachsen und Niederschlesien" :
>     [295743,5511505,709358,5755456]
>             ]]></param>
>             <param
>              <param name="measure_tool.show_area_segments">false</param>
>             <param name="layer_controls.legend.on">false</param>
>             <param name="layer_controls.up.on">false</param>
>             <param name="layer_controls.down.on">false</param>
>             <param name="layer_controls.metadata.on">false</param>
>             <param name="layer_controls.legend.on">true</param>
>             <param name="group_checkboxes">false</param>
>             <param name="default_tab">Catalog</param>
>             <param name="ground_units">m</param>
>             <param name="maxResolution">156543.03390625</param>
>             <param name="numZoomLevels">20</param>
>             <param name="coordinate_display.usng">false</param>
>              <param name="jumpto_scales"><![CDATA[
>                 "1:100000" : 100000,
>                 "1:50000" : 50000,
>                 "1:24000" : 24000,
>                 "1:10000" : 10000,
>                 "1:5000" : 5000
>         ]]></param>/
>     When I change the coordinates of max_extent then GeoMOOSE shows
>     another area. Maybe there is the problem? When I set the
>     fractional_zoom to true, the osm tiles will be displayed pink.
>     4. I changed the projection of the map in local_settings.ini and
>     settings.ini:
>     /[map]
>     projection=EPSG:25833/
>     That is what I have done. Is there anywhere a reference to the
>     "old" projection of EPSG:26915? Anything I have missing?
>     Unfortunately I have no own data, that I can proof, because there
>     is a mistake in the map file of the data's source.
>     Thanks a lot for your help!
>     Greetings, Geograefin
>     *Gesendet:* Montag, 05. Januar 2015 um 22:16 Uhr
>     *Von:* "TC Haddad" <tchaddad at gmail.com>
>     *Betreff:* Re: Re: [Geomoose-users] Change projection
>     Let's back up - can you describe your symptoms in more detail?
>     - You started from the demo
>     - You made your projection changes and something didn't work
>     - is your data displaying correctly in the map?
>     - do you get a pink screen when you try to view your data?
>     - are the coordinates displaying below the map incorrect? or
>     duplicated in 2 projections?
>     More items to double check or try:
>     - Did you set appropriate initial and maximum extent values in the
>     Mapbook?
>     ie.     <param
>     name="max_extent">7110968,-610403,9234765,956456</param>
>             <param
>     name="initial_extent">7296650,228568,7570144,408049</param>
>     - Did you set the correct units in the Mapbook?
>             <param name="ground_units">ft</param>
>     - Did you set appropriate zoom levels in the Mapbook?
>             <param name="fractional_zoom">true</param>
>             <param
>     name="scales">0.25,0.5,1,2,4,8,16,32,64,128,256,512,1024,2048</param>
>     On Mon, Jan 5, 2015 at 11:14 AM, <geo.graefin at web.de> wrote:
>         Thank you for your answer,
>         I did all the steps, including the both of your answer. I
>         really have no idea, what is wrong. Maybe the
>         local_settings.ini could not overwrite the settings.ini?
>         *Gesendet:* Montag, 05. Januar 2015 um 18:10 Uhr
>         Some ideas to check if you started from the Demo file:
>           * Did you place the epsg25833.js file that you created in
>             Step 2 in the projections directory?
>           * Did you remove the reference to the old projection from
>             your HTML? ie.
>             delete <script type=”text/javascript”
>             src=”projections/EPSG26915.js”></script>
>             insert <script type=”text/javascript”
>             src=”projections/EPSG25833.js”></script>
>         On Mon, Jan 5, 2015 at 8:35 AM, <geo.graefin at web.de
>         <http://geo.graefin@web.de>> wrote:
>             Dear community,
>             I have problems with changing the projection of my
>             GeoMOOSE project. I have followed the instructions at the
>             GeoMOOSE site
>             [http://docs.geomoose.org/2.7/docs/projections.html]. In
>             addition to all these steps I changed the EPSG code in
>             local_settings.ini. But there is no effect.  It still
>             shows the projection (EPSG code 26915) of the demo, as
>             well as the coordinates x,y at the status bar. The "new"
>             epsg code is 25833.
>             Do you have any ideas, what instructions are missing or
>             what i did wrong?
>             I would be very grateful for help! Thank you in advance!
>             _______________________________________________
>             Geomoose-users mailing list
>             Geomoose-users at lists.osgeo.org
>             <http://Geomoose-users@lists.osgeo.org>
>             http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150106/45157291/attachment-0001.html>
More information about the Geomoose-users
