[Geomoose-users] Change projection
TC Haddad
tchaddad at gmail.com
Wed Jan 7 08:37:06 PST 2015
the coordinates in your initial extent must be in the 3857 projection,
while the below look like 4326 coordinates
*<param name="initial_extent">13.7,50.6,15.3,51.8</param>*
On Wed, Jan 7, 2015 at 8:25 AM, <geo.graefin at web.de> wrote:
> So, when I will use the projection EPSG:3857 as the only one (and not
> EPSG:25833) then I have to set this...?
> *<param name="projection">EPSG:3857</param>*
> What about the x/y? Because the cartesian system is missing?
> Thanks for helping!
> *Gesendet:* Mittwoch, 07. Januar 2015 um 17:04 Uhr
> *Von:* "Brent Fraser" <bfraser at geoanalytic.com>
> *An:* geo.graefin at web.de, geomoose-users at lists.osgeo.org
> *Betreff:* Re: Aw: Re: [Geomoose-users] Change projection
> That's because you've set you display projection to something other than
> EPSG:3857 (likely EPSG:25833?). It is NOT necessary to change the display
> projection just to display your own data. If you want to use standard
> basemap tiles like OSM, Google, etc, then you MUST use a display projection
> of EPSG:3857.
> Best Regards,
> Brent Fraser
> On 1/7/2015 7:14 AM, geo.graefin at web.de wrote:
> Sorry, I have forgotten the appendix with the screenshot of GeoMOOSE.
> *Gesendet:* Mittwoch, 07. Januar 2015 um 14:46 Uhr
> *Von:* geo.graefin at web.de
> *An:* "Brent Fraser" <bfraser at geoanalytic.com>
> <http://bfraser@geoanalytic.com>, geomoose-users at lists.osgeo.org
> *Betreff:* Aw: Re: [Geomoose-users] Change projection
> Thank you for checking. But the new projection still doesn't work, see
> appendix. It is showing the area somewhere over France, actually it has to
> show the east of Germany.
> Greetings, Geograefin
> *Gesendet:* Dienstag, 06. Januar 2015 um 17:40 Uhr
> *An:* geo.graefin at web.de, "GeoMOOSE Users List"
> <geomoose-users at lists.osgeo.org> <http://geomoose-users@lists.osgeo.org>
> *Betreff:* Re: [Geomoose-users] Change projection
> 2.6.1 works fine too.
> Best Regards,
> Brent Fraser
> On 1/6/2015 8:57 AM, Brent Fraser wrote:
> Geograefin,
> I don't think 2.6 is very different with the way it handles coordinate
> systems, but I will try it to make sure.
> Your web mapping site can have only one display coordinate system (e.g.
> EPSG:3857, or EPSG:25833) at a time, but each of your local data sets can
> be in any coordinate system. Mapserver can re-project them to the target
> display coordinate system if you give enough information in your Mapserver
> map files.
> I used your estimates for the extents in the mapbook.xml
> <param name="max_extent">100000,1000000,999999,9999999</param>
> <param name="initial_extent">295743,5511505,709358,5755456</param>
> Best Regards,
> Brent Fraser
> On 1/6/2015 8:03 AM, geo.graefin at web.de wrote:
> Dear Brant Fraser,
> thank you for your answer!
> I use GeoMOOSE 2.6. Does this make a difference?
> Cannot I use several coordinate systems (EPSG:25833 and EPSG:3857)?
> What have you entered as the max_extent in mapbook.xml?
> Sincerely, Geograefin
> *Gesendet:* Dienstag, 06. Januar 2015 um 15:11 Uhr
> Geograephin,
> I followed the instructions and got something reasonable:
> <deleted image>
> How can you tell your setup is not working properly?
> (Note that only the ArcGIS server will return tiles in the EPSG:25833
> coordinate system for the Background group).
> Best Regards,
> Brent Fraser
> On 1/6/2015 6:06 AM, geo.graefin at web.de wrote:
> Hello,
> here more in detail what I did:
> 1. I created a new js file including the declaration of the EPSG code
> from spatialreference.org and deleted the one of EPSG:26915.
> *Proj4js.defs["EPSG:25833"] = "+proj=utm +zone=33 +ellps=GRS80 +units=m
> +no_defs";*
> 2. I referenced this new js file in geomoose.html. Beside there is another
> projection for the geographic coordinates (EPSG:3857). I deleted the
> reference of EPSG:26915.
> *<script type="text/javascript" src="projections/EPSG3857.js"></script>
> <script type="text/javascript" src="projections/EPSG25833.js"></script>*
> 3. I changed the parameters projection, max_extent and initial_extent in
> mapbook.xml.
> *<param name="projection">EPSG:25833</param> <param
> name="zoomto"><![CDATA[ { "Zoom To:" : {
> "Sachsen und Niederschlesien" : [295743,5511505,709358,5755456]
> } } ]]></param> <param
> name="max_extent">100000,1000000,999999,9999999</param> <param
> name="initial_extent">295743,5511505,709358,5755456</param> <param
> name="measure_tool.show_area_segments">false</param> <param
> name="layer_controls.legend.on">false</param> <param
> name="layer_controls.up.on">false</param> <param
> name="layer_controls.down.on">false</param> <param
> name="layer_controls.metadata.on">false</param> <param
> name="layer_controls.legend.on">true</param> <param
> name="group_checkboxes">false</param> <param
> name="default_tab">Catalog</param> <param
> name="ground_units">m</param> <param
> name="maxResolution">156543.03390625</param> <param
> name="numZoomLevels">20</param> <param
> name="coordinate_display.usng">false</param> <param
> name="jumpto_scales"><![CDATA[ { "1:100000" : 100000,
> "1:50000" : 50000, "1:24000" : 24000,
> "1:10000" : 10000, "1:5000" : 5000 } ]]></param>*
> When I change the coordinates of max_extent then GeoMOOSE shows another
> area. Maybe there is the problem? When I set the fractional_zoom to true,
> the osm tiles will be displayed pink.
> 4. I changed the projection of the map in local_settings.ini and
> settings.ini:
> *[map] projection=EPSG:25833*
> That is what I have done. Is there anywhere a reference to the "old"
> projection of EPSG:26915? Anything I have missing?
> Unfortunately I have no own data, that I can proof, because there is a
> mistake in the map file of the data's source.
> Thanks a lot for your help!
> *Gesendet:* Montag, 05. Januar 2015 um 22:16 Uhr
> *Von:* "TC Haddad" <tchaddad at gmail.com>
> *Betreff:* Re: Re: [Geomoose-users] Change projection
> Let's back up - can you describe your symptoms in more detail?
> - You started from the demo
> - You made your projection changes and something didn't work
> - is your data displaying correctly in the map?
> - do you get a pink screen when you try to view your data?
> - are the coordinates displaying below the map incorrect? or duplicated in
> 2 projections?
> More items to double check or try:
> - Did you set appropriate initial and maximum extent values in the Mapbook?
> ie. <param name="max_extent">7110968,-610403,9234765,956456</param>
> <param name="initial_extent">7296650,228568,7570144,408049</param>
> - Did you set the correct units in the Mapbook?
> <param name="ground_units">ft</param>
> - Did you set appropriate zoom levels in the Mapbook?
> <param name="fractional_zoom">true</param>
> <param
> name="scales">0.25,0.5,1,2,4,8,16,32,64,128,256,512,1024,2048</param>
> On Mon, Jan 5, 2015 at 11:14 AM, <geo.graefin at web.de> wrote:
>> Thank you for your answer,
>> I did all the steps, including the both of your answer. I really have no
>> idea, what is wrong. Maybe the local_settings.ini could not overwrite the
>> settings.ini?
>> *Gesendet:* Montag, 05. Januar 2015 um 18:10 Uhr
>> Some ideas to check if you started from the Demo file:
>> - Did you place the epsg25833.js file that you created in Step 2 in
>> the projections directory?
>> - Did you remove the reference to the old projection from your HTML?
>> ie.
>> delete <script type=”text/javascript”
>> src=”projections/EPSG26915.js”></script>
>> insert <script type=”text/javascript”
>> src=”projections/EPSG25833.js”></script>
>> On Mon, Jan 5, 2015 at 8:35 AM, <geo.graefin at web.de> wrote:
>>> Dear community,
>>> I have problems with changing the projection of my GeoMOOSE project. I
>>> have followed the instructions at the GeoMOOSE site [
>>> http://docs.geomoose.org/2.7/docs/projections.html]. In addition to all
>>> these steps I changed the EPSG code in local_settings.ini. But there is no
>>> effect. It still shows the projection (EPSG code 26915) of the demo, as
>>> well as the coordinates x,y at the status bar. The "new" epsg code is 25833.
>>> Do you have any ideas, what instructions are missing or what i did wrong?
>>> I would be very grateful for help! Thank you in advance!
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150107/933f02d5/attachment-0001.html>
More information about the Geomoose-users
