[Geomoose-users] PROBLEM TO LOAD A TABLE IN GEOMOOSE
Dan Little
theduckylittle at gmail.com
Fri May 15 06:30:13 PDT 2015
Can you attach your mapbook and specify which layer is giving you problems?
That error usually only happens when you've incorrectly specified a
path in a <layer> tag.
On Mon, May 11, 2015 at 1:16 PM, Víctor M. Montes Ordóñez
<i82moorv at uco.es> wrote:
> Hi everyone. I try to load some sheaps for my project in GeoMoose, but when
> i try to load a shape, appears this error message:
> "GeoMOOSE.changeLayerVisibility: map-source for path (directory of file)
> undefined."
> I work loading every shape and add as a layer in file "mapbook.xml".
> Any solution to this problem??
> Thanks a lot!! Regards!!
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
