[Geomoose-users] REST Services
Mark Volz
MarkVolz at co.lyon.mn.us
Thu Nov 5 06:27:22 PST 2015
Tim,
1) It looks like you did not specify a projection, therefore ArcGIS will serve the map but It apparently will not serve it in the same projection you are using. I think it defaults to web Mercator now? Try adding the projection and maybe things will work.
2) In your code snippet you referenced "ags/sirens" instead of layer "1". Please let me know if you can get GeoMOOSE to work with ArcServer by referencing the layer by name instead of the number.
3) I forgot to mention previously that in GeoMOOSE that perhaps all the tools such as buffering, identify, etc work through MapServer. You can display layers from ArcServer, but that is about all you can do with ArcServer tools.
Sincerely,
Mark Volz, GISP
From: Tim Hennig [mailto:timhbellevue at gmail.com]
Sent: Thursday, November 05, 2015 7:58 AM
To: Mark Volz; geomoose-users at lists.osgeo.org
Subject: RE: [Geomoose-users] REST Services
Hi Mark,
Thanks for the reply!
I see what I did wrong....
<layer title="Test" src="Sirens" show-legend="false" legend="false" fade="false" unfade="false"/>
src = "ags/sirens"
I set the source wrong. It works now!
However, I might have a projection issue, not sure how. The REST data is not overlaying. Hmmmm....
Tim Hennig
Sent: Wednesday, November 04, 2015 4:31 PM
To: Tim Hennig; geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Tim,
For some reason ArcGIS likes to use numbers for layer names...
<map-source name="PictometryArcServer" type="wms" reference="false" projection='EPSG:103749' tiled="true" width='256' height='256' transition_Effect="resize">
<url>http://gis.lyonco.org/arcgis/services/LyonGIS/Basemap_AirPhotos/MapServer/WMSServer?</url<http://gis.lyonco.org/arcgis/services/LyonGIS/Basemap_AirPhotos/MapServer/WMSServer?%3c/url>>
<layer name="1"/>
<layer name="2"/>
<layer name="3"/>
<layer name="4"/>
<param name="STYLES" value=""/>
</map-source>
Sincerely,
Mark Volz, GISP
From: Geomoose-users [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Tim Hennig
Sent: Wednesday, November 04, 2015 3:59 PM
To: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Subject: [Geomoose-users] REST Services
Hi Everyone,
I am trying to incorporate a ArcGIS REST Service from a county server.
I am having no luck with this, can anyone help me regarding this. Here is my test syntax.
<map-source name="ags" type="ags">
<url>http://maps.gis.co.brown.wi.us/arcgis/rest/services/Sirens/MapServer/Export</url<http://maps.gis.co.brown.wi.us/arcgis/rest/services/Sirens/MapServer/Export%3c/url>>
<layer name="Sirens"/>
<param name="FORMAT" value="PNG"/>
</map-source>
This is my error message from FireBug (No pink screen).
TypeError: this._modalconnects is undefined
...ferred){this._fadeOutDeferred.cancel();}this._modalconnects.push(dojo.connect(wi...
dojo.js (line 14, col 297062)
Thank you,
Tim Hennig
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20151105/8876f414/attachment-0001.html>
More information about the Geomoose-users
