[Geomoose-users] REST Services
TC Haddad tchaddad at gmail.com
Thu Nov 5 15:17:08 PST 2015
Hi Tim,
Just one more idea to explore: when I look at the service page here:
http://maps.gis.co.brown.wi.us/arcgis/rest/services/Sirens/MapServer
I see that the only projection supported is:103404 which (I believe) is not
an EPSG code (it looks like an ESRI code, but does not come up at
www.spatialreference.org). It could be that the server is not set to
respond to requests using EPSG codes?
Either way, if you are a stakeholder / constituent of / friendly with the
service owner, I always feel that it is worth politely asking if they are
willing to "turn on" WMS support for their services - it's a simple check
box or two in the configuration on their side, and it really does serve
customers of all kinds, rather than just perpetuating vendor lock-in.
One reason governments are persuaded to buy from the big vendors is that
they "support all the standards" after all - so any opportunity for users
to encourage turning these features on is really just asking for your
money's worth as a tax payer....
Tanya
On Thu, Nov 5, 2015 at 2:29 PM, Tim Hennig <timhbellevue at gmail.com> wrote:
> Hi Mark,
> I was able to call the REST service by name.  I forgot to add the src =
> “ags/sirens”.   Everything works (no errors in Firebug) except the
> projection/overlay.
> I did add the projection='EPSG:2929’ within the map-source tag.  This did
> not help.
> I tried all the image formats to see if by chance it would overlay.  No
> luck.
> I am stumped.
> Thanks,
> Tim Hennig
> *From:* Mark Volz [mailto:MarkVolz at co.lyon.mn.us]
> *Sent:* Thursday, November 05, 2015 8:27 AM
> *To:* Tim Hennig; geomoose-users at lists.osgeo.org
> *Subject:* RE: [Geomoose-users] REST Services
> Tim,
> 1)      It looks like you did not specify a projection, therefore ArcGIS
> will serve the map but It apparently will not serve it in the same
> projection you are using.  I think it defaults to web Mercator now?  Try
> adding the projection and maybe things will work.
> 2)      In your code snippet you referenced “ags/sirens” instead of layer
> “1”.  Please let me know if you can get GeoMOOSE to work with ArcServer by
> referencing the layer by name instead of the number.
> 3)      I forgot to mention previously that in GeoMOOSE that perhaps all
> the tools such as buffering, identify, etc work through MapServer.  You can
> display layers from ArcServer, but that is about all you can do with
> ArcServer tools.
> Sincerely,
> *Mark Volz, GISP*
> *From:* Tim Hennig [mailto:timhbellevue at gmail.com <timhbellevue at gmail.com>]
> *Sent:* Thursday, November 05, 2015 7:58 AM
> *To:* Mark Volz; geomoose-users at lists.osgeo.org
> Hi Mark,
> Thanks for the reply!
> I see what I did wrong….
>                 <layer title="Test" src="Sirens" show-legend="false"
> legend="false" fade="false" unfade="false"/>
>                 src = “ags/sirens”
> I set the source wrong.  It works now!
> However, I might have a projection issue, not sure how.  The REST data is
> not overlaying.  Hmmmm….
> Tim Hennig
> *From:* Mark Volz [mailto:MarkVolz at co.lyon.mn.us <MarkVolz at co.lyon.mn.us>]
> *Sent:* Wednesday, November 04, 2015 4:31 PM
> Tim,
> For some reason ArcGIS likes to use numbers for layer names…
>                 <map-source name="PictometryArcServer" type="wms"
> reference="false" projection='EPSG:103749' tiled="true" width='256'
> height='256' transition_Effect="resize">
>                                 <url>
> http://gis.lyonco.org/arcgis/services/LyonGIS/Basemap_AirPhotos/MapServer/WMSServer?</url
>                                 *                <layer name="1"/>*
> *                                                <layer name="2"/>*
> *                                                <layer name="3"/>*
> *                                                <layer name="4"/>*
>                                                 <param name="STYLES"
> value=""/>
>                 </map-source>
> Sincerely,
> *Mark Volz, GISP*
> *From:* Geomoose-users [mailto:geomoose-users-bounces at lists.osgeo.org
> <geomoose-users-bounces at lists.osgeo.org>] *On Behalf Of *Tim Hennig
> *Sent:* Wednesday, November 04, 2015 3:59 PM
> *To:* geomoose-users at lists.osgeo.org
> *Subject:* [Geomoose-users] REST Services
> Hi Everyone,
> I am trying to incorporate a ArcGIS REST Service from a county server.
> I am having no luck with this, can anyone help me regarding this.  Here is
> my test syntax.
>                 <map-source name="ags" type="ags">
>                                 <url>
> http://maps.gis.co.brown.wi.us/arcgis/rest/services/Sirens/MapServer/Export</url
>                                 <layer name="Sirens"/>
>                                 <param name="FORMAT" value="PNG"/>
>                 </map-source>
> This is my error message from FireBug (No pink screen).
> TypeError: this._modalconnects is undefined
> ...ferred){this._fadeOutDeferred.cancel();}this._modalconnects.push(dojo.connect(wi...
> dojo.js (line 14, col 297062)
> Thank you,
> Tim Hennig
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20151105/4a583300/attachment-0001.html>
More information about the Geomoose-users mailing list
