[Geomoose-users] highlighting missing from select feature tool - MS4W
Mark Volz
MarkVolz at co.lyon.mn.us
Thu Nov 12 12:18:12 PST 2015
Jeff,
Thank you for offering to take a look. I think there may indeed be an issue with MS4W not being able to read DB files. I put together a test file located at http://geomoose.lyonco.org/DBTest/DBConnectionTest.zip
*Unzip the file to /ms4w/tmp/ms_tmp
*There is a test url bookmark that will open up http://localhost/cgi-bin/mapserv.exe?service=WMS&version=1.1.1&request=GetMap&styles=&format=image%2Fjpeg&MAP=%2Fms4w%2Ftmp%2Fms_tmp%2F%2Fselect_132761447356573.map&FORMAT=image%2Fpng&TRANSPARENT=true&LAYERS=highlight&SRS=EPSG%3A3857&_OLSALT=0.5711829908262914&BBOX=-10375479.594299,5556082.9582284,-10370821.712889,5558810.804675&WIDTH=975&HEIGHT=571
*I included a shapefile variation of the mapfile to demonstrate that shapefiles work.
Thanks
Sincerely,
Mark Volz, GISP
Lyon County GIS Coordinator
504 Fairgrounds Rd
Marshall, MN 56258
Ph: (507) 532-8218
Fax: (507) 532-8217
http://lyonco.org/
> -----Original Message-----
> From: Geomoose-users [mailto:geomoose-users-bounces at lists.osgeo.org] On
> Behalf Of Jeff McKenna
> Sent: Thursday, November 12, 2015 11:46 AM
> To: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] highlighting missing from select feature tool -
> MS4W
> Hi Mark,
> Do you think this is a problem with the MS4W packaging? Let me know if you
> want me to do some testing.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 2015-11-09 4:35 PM, Mark Volz wrote:
> > Hello,
> > I noticed that while GeoMOOSE 2.8.1 and MS4W 3.1.0 that the highlighting
> > is missing from the select tool. The results of select appear to be
> > fine, but I cannot see any highlighting.
> > Has anyone else noticed this issue? If anyone has an idea as to how I
> > can fix the problem with MS4W let me know.
> > Thank You!
> > Sincerely,
> > Mark Volz
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
