[Geomoose-users] query.php results to CSV
Dan Little
theduckylittle at gmail.com
Tue Sep 8 12:21:01 PDT 2015
This will be coming but I can't promise a timeline. The RFC #5
happens to cover this functionality but I need to get to it.
On Tue, Sep 8, 2015 at 2:16 PM, Matej Mailing <mailing at tam.si> wrote:
> I have checked the code of mailing labels, but it seems to be using
> sqlite db. My goal is to export exactly the same results as query.php
> from GM is returning (with their comparitors etc.).
> Basically in the query.php all the data is returned via
> $map->processquerytemplate(array(), MS_FALSE);
> which is filtered with
> $queryLayer->setFilter($filter_string);
> The data is returned from Mapserver and as the last resort I can build
> the pgsql query myself from the $filter_string and the name of the
> layer, but I am looking for a solution where it would work for any
> layer (for example we provide a Mapfile/Layer information here, but in
> the pgsql way you need table name, authentication params etc., which
> of course are already defined in the Mapfile ....)
> The ideal solution would be to somehow get a generated query that
> Mapserver runs when it pulls out the results and just iterate through
> them and output as CSV - but I can't find any useful method in
> Mapscript documentation for that. Any ideas are very welcome :-)
> Hopefully I am not being too confusing with this :-)
> Thanks,
> Matej
> 2015-09-08 18:25 GMT+02:00 Dan Little <theduckylittle at gmail.com>:
>> You might want to take a look at the mailing labels code, we do
>> exactly that in there.
>> On Tue, Sep 8, 2015 at 6:24 AM, Matej Mailing <mailing at tam.si> wrote:
>>> Hi,
>>> what would be the best way to export query.php results as CSV?
>>> Thanks!
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
