[Geomoose-users] Geomoose Hosting
Jim Klassen klassen.js at gmail.com
Tue Aug 16 10:35:42 PDT 2016
Also note that in particular, mapserver_url is the (usually relative)
URL to where mapserver can be found.
As it is written, you are telling GeoMoose to look for the mapserver CGI at:
http://gene.webfactional.com/home/gene/bin/mapserv
which is probably not what you want.
You will need a ScriptAlias (and possibly a Directory entry to setup
permissions) in your Apache configuration (or equivalent) to enable
Apache to see /home/gene/bin as a URL.
e.g.
ScriptAlias /home/gene/bin/ /gene-bin/
Then mapserver_url=/gene-bin/mapserv
temp needs to be a directory that the web server user can read/write so
the PHP can store temporary files.  I don't believe it needs to be
directly accessible via URL.
Also, don't forget to set the temp directory in
'./maps/temp_directory.map' for MapServer.
On 08/16/2016 09:03 AM, Brent Fraser wrote:
> Janet,
>   Both paths:
> mapserver_url=/home/gene/bin/mapserv
> temp=//home/gene/tmp/ms_tmp/
> need to be related (mapped) to URLs.  You can do this in the
> httpd.conf file of your Apache web server.
> Best Regards,
> Brent Fraser
> On 8/15/2016 11:59 PM, Janet Maina wrote:
>> Am trying to host geomoose in unix and am almost 95%. but i get a
>> pink page
>> check 'http://gene.webfactional.com/geomoose/htdocs/geomoose.html
>> <http://gene.webfactional.com/geomoose/htdocs/geomoose.html>
>> ============my local_settings.ini'==============
>> [paths]
>> root=/home/gene/webapps/test/geomoose/maps/
>> mapserv was installed to bin so i changed cgi-bin to bin.
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160816/3cefccd0/attachment-0001.html>
More information about the Geomoose-users mailing list
