[Geomoose-users] Geomoose buttons not working
Eli Adam
eadam at co.lincoln.or.us
Thu Dec 1 13:09:15 PST 2016
On Thu, Dec 1, 2016 at 12:41 PM, Caitlin Christenson
<caitlinprodoehl at co.stevens.mn.us> wrote:
> I think there’s an issue in your configuration file.
> From: Geomoose-users [mailto:geomoose-users-bounces at lists.osgeo.org] On
> Behalf Of Janet Maina
> Sent: Thursday, December 01, 2016 2:31 PM
> To: geomoose-users at lists.osgeo.org
> Subject: [Geomoose-users] Geomoose buttons not working
> Hey am having a problem when I host geomoose in unix environment. some
> buttons like print, identify don't work. check in
> 'http://www.waterresources.co.ke/data/htdocs/geomoose.html'
> i get this error
> The service you called did not return valid XML. If you are the system
> administrator, you should look into this, if you are not the system
> administrator you should tell them about this.
Troubleshooting with Firebug or something similar might help. Using
Firebug, I found this response to the search error:
<br />
<b>Fatal error</b>: Call to undefined function ms_newprojectionobj()
in <b>/home/gene/webapps/test/data/htdocs/php/query.php</b> on line
<b>31</b><br />
Identify:
<br />
<b>Fatal error</b>: Call to undefined function ms_shapeObjFromWkt()
in <b>/home/gene/webapps/test/data/htdocs/php/identify.php</b> on line
<b>96</b><br />
print:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL /mapserver.cgi was not found on this server.</p>
</body></html>
<br />
<b>Fatal error</b>: Call to undefined function ms_newMapObj() in
<b>/home/gene/webapps/test/data/htdocs/php/print_util.php</b> on line
<b>301</b><br />
This all seems to point to MapServer not being found or accessible.
Firebug will help find these problems and find how to fix them.
Best regards, Eli
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
