[Geomoose-users] Geomoose buttons not working
Dan Little
theduckylittle at gmail.com
Mon Dec 5 07:36:47 PST 2016
Please keep all of your responses going to the user's list in case
future users have the same problems.
This looks like you are using Linux. Which distribution are you
trying to install it on?
On Sun, Dec 4, 2016 at 3:23 AM, Janet Maina <madamjanet92 at gmail.com> wrote:
> Here are the commands that I did to install mapserver but am using geomoose
> 2.9
> mkdir src
> cd src
> wget http://download.osgeo.org/mapserver/mapserver-6.2.2.tar.gz
> tar -xf mapserver-6.2.2.tar.gz
> cd mapserver-6.2.2
> ./configure --prefix=$HOME --with-gif=no --with-fastcgi=no --with-proj
> --with-gdal --with-ogr --with-postgis=/usr/bin/pg_config --with-wfs
> make
> make install
> On Fri, Dec 2, 2016 at 10:34 PM, Dan Little <theduckylittle at gmail.com>
> wrote:
>> How was the application install? MS4W? Which instructions did you use?
>> On Thu, Dec 1, 2016 at 3:09 PM, Eli Adam <eadam at co.lincoln.or.us> wrote:
>> > On Thu, Dec 1, 2016 at 12:41 PM, Caitlin Christenson
>> > <caitlinprodoehl at co.stevens.mn.us> wrote:
>> >> I think there’s an issue in your configuration file.
>> >> From: Geomoose-users [mailto:geomoose-users-bounces at lists.osgeo.org] On
>> >> Behalf Of Janet Maina
>> >> Sent: Thursday, December 01, 2016 2:31 PM
>> >> To: geomoose-users at lists.osgeo.org
>> >> Subject: [Geomoose-users] Geomoose buttons not working
>> >> Hey am having a problem when I host geomoose in unix environment.
>> >> some
>> >> buttons like print, identify don't work. check in
>> >> 'http://www.waterresources.co.ke/data/htdocs/geomoose.html'
>> >> i get this error
>> >> The service you called did not return valid XML. If you are the system
>> >> administrator, you should look into this, if you are not the system
>> >> administrator you should tell them about this.
>> > Troubleshooting with Firebug or something similar might help. Using
>> > Firebug, I found this response to the search error:
>> > <br />
>> > <b>Fatal error</b>: Call to undefined function ms_newprojectionobj()
>> > in <b>/home/gene/webapps/test/data/htdocs/php/query.php</b> on line
>> > <b>31</b><br />
>> > Identify:
>> > <br />
>> > <b>Fatal error</b>: Call to undefined function ms_shapeObjFromWkt()
>> > in <b>/home/gene/webapps/test/data/htdocs/php/identify.php</b> on line
>> > <b>96</b><br />
>> > print:
>> > <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
>> > <html><head>
>> > <title>404 Not Found</title>
>> > </head><body>
>> > <h1>Not Found</h1>
>> > <p>The requested URL /mapserver.cgi was not found on this server.</p>
>> > </body></html>
>> > <br />
>> > <b>Fatal error</b>: Call to undefined function ms_newMapObj() in
>> > <b>/home/gene/webapps/test/data/htdocs/php/print_util.php</b> on line
>> > <b>301</b><br />
>> > This all seems to point to MapServer not being found or accessible.
>> > Firebug will help find these problems and find how to fix them.
>> > Best regards, Eli
>> >> _______________________________________________
>> >> Geomoose-users mailing list
>> >> Geomoose-users at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
