[Geomoose-users] Printing not working
TC Haddad
tchaddad at gmail.com
Wed Dec 14 09:41:56 PST 2016
Can you check that the path to your tmp directory is set correctly in
local_settings.ini?
On Wed, Dec 14, 2016 at 7:42 AM, Kevin Grootendorst <kgrootendorst at gmail.com
> wrote:
> Dear users,
> I'm getting an error that I can't seem to decipher. I'm trying to use the
> Print tool in GeoMoose. I'm presented with the title, size options, etc.,
> but when I click 'Go', I get the following error in Firebug:
> [image: Inline image 2]
> And in the Apache error log:
> [Wed Dec 14 10:38:16.226718 2016] [:error] [pid 29622] [client
> 24.157.101.143:65421] PHP Fatal error: Uncaught exception
> 'MapScriptException' with message 'Failed to open map file "/tmp/out/sketch_148172989629622.map",
> or map file error.' in /var/www/geomoose-2.8.1/
> htdocs/php/print_util.php:353\nStack trace:\n#0 /var/www/geomoose-2.8.1/
> htdocs/php/print_util.php(353): ms_newMapObj('/tmp/out/sketch...',
> '/var/www/geomoo...')\n#1 /var/www/geomoose-2.8.1/
> htdocs/php/print_util.php(223): renderVector(Array, 1600, 1400,
> Array)\n#2 /var/www/geomoose-2.8.1/htdocs/php/print.php(133):
> renderImage(Object(DOMDocument), Array, 1600, 1400, Array, false)\n#3
> {main}\n thrown in /var/www/geomoose-2.8.1/htdocs/php/print_util.php on
> line 353, referer: http://www.mysite.ca/geomoose/geomoose.html
> In my experience, this is likely a path issue. I have checked my tmp/out
> folder and there is no file there, so perhaps that is throwing the error.
> Any ideas?
> Thanks, Kevin
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161214/a8766656/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161214/a8766656/attachment.png>
More information about the Geomoose-users
