[Geomoose-users] identify php Internal Server Error
Kevin Grootendorst
kgrootendorst at gmail.com
Tue Nov 8 06:00:32 PST 2016
That was it! Thanks Dan.
The identify tool is now working as expected.
On Tue, Nov 8, 2016 at 7:44 AM, Dan Little <theduckylittle at gmail.com> wrote:
> It helps quite a bit! In your local_settings.ini file add a "/" to the end
> of the path for mapfile_root.
> On Mon, Nov 7, 2016 at 8:52 PM, Kevin Grootendorst <
> kgrootendorst at gmail.com> wrote:
>> Hi Dan,
>> I found this in the log file, but I don't know if it helps.
>> [image: Inline image 1]
>> On Mon, Nov 7, 2016 at 5:02 PM, Dan Little <theduckylittle at gmail.com>
>> wrote:
>>> That's odd, generally the demo does work pretty flawlessly right out of
>>> the box.
>>> Can you check your Apache error log?
>>> On Mon, Nov 7, 2016 at 4:00 PM, Kevin Grootendorst <
>>>> Dear users, I have installed GeoMoose 2.9 and running into issues with
>>>> the identify tool.
>>>> When I use identify using the demo data, I always get a 500 internal
>>>> server error, and a msg 'Error: Unable to load php/identify.php
>>>> status:500'.
>>>> I can't seem to figure out why identify isn't able to load. The file
>>>> exists in the right location.
>>>> I was thinking it was a projection issue? But perhaps not.. I expected
>>>> the demo to work flawlessly which uses different spatial references.
>>>> Thanks,
>>>> Kevin
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161108/1ee322fe/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161108/1ee322fe/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161108/1ee322fe/attachment-0003.png>
More information about the Geomoose-users
