[Geomoose-users] Query a Mapserver raster group
    andy
    aborruso at gmail.com
    Fri Feb  3 09:39:57 PST 2017
Hi James,
On 3 February 2017 at 18:05, James Klassen <klassen.js at gmail.com> wrote:
> So you need the DEM layer with a valid template and the cosmetic layer
> with just something like
> TEMPLATE 'dummy'
I’m able to load the group and I’m able to query the single DEM file (below
my settings).
But if I load the group and the click on the map I have no query output.
If I look to log file I see that I have msRasterQueryByRect action for
other raster layer, but not for the loaded group.
Is it normal? Could it be a small bug related to query a raster query group?
Thank you
  LAYER
    DATA "dem.tif"
    EXTENT 369957.267038251 4124951.49692997 378066.716402869 4133060.94629459
    GROUP "DEMG"
    METADATA
      "coordsys_name"    "WGS 84 / UTM zone 33N"
      "ows_title"    "dem"
      "identify_record"    "dem.html"
      "wms_group_title"    "DEMG"
    END # METADATA
    NAME "dem"
    PROJECTION
      "proj=utm"
      "zone=33"
      "datum=WGS84"
      "units=m"
      "no_defs"
    END # PROJECTION
    STATUS ON
    TEMPLATE "dem.html"
    TILEITEM "location"
    TOLERANCE 0
    TYPE RASTER
    UNITS METERS
    CLASS
      NAME "dem"
    END # CLASS
  END # LAYER
  LAYER
    DATA "cosmetic.tif"
    GROUP "DEMG"
    METADATA
      "ows_title"    "cosmetic"
      "identify_record"    "dummy"
    END # METADATA
    NAME "cosmetic"
    PROJECTION
      "proj=utm"
      "zone=33"
      "datum=WGS84"
      "units=m"
      "no_defs"
    END # PROJECTION
    STATUS ON
    TEMPLATE "dummy"
    TILEITEM "location"
    TOLERANCE 0
    TYPE RASTER
    UNITS METERS
    CLASS
      NAME "cosmetic"
    END # CLASS
  END # LAYER
Andrea Borruso
website: http://blog.spaziogis.it
38° 7’ 48” N, 13° 21’ 9” E, EPSG:4326
“cercare e saper riconoscere chi e cosa,
in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio”
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170203/b754228b/attachment.html>
More information about the Geomoose-users
