[Geomoose-users] GeoMOOSE searching GeoNetwork metadata
Dan Little
theduckylittle at gmail.com
Fri Feb 3 11:32:09 PST 2017
Summer 2017 should see the release of 3.0.
On Feb 3, 2017 12:36, "Kevin Grootendorst" <kgrootendorst at gmail.com> wrote:
> Good to know, thanks Dan.
> So this leads to the question.... do you have a ballpark release date for
> GM3?
> Cheers, Kevin
> On Fri, Feb 3, 2017 at 11:29 AM, Dan Little <theduckylittle at gmail.com>
> wrote:
>> It depends on what your timeframe is. One of our design goals was to
>> make the dynamic addition/removal of layers from both the map and the
>> catalog much easier in GM3. We're actually trying to keep things like
>> interacting with CSW catalogs in mind.
>> Thus starts what will basically be the next year's of "But we can do that
>> in GM3!!!"
>> On Thu, Feb 2, 2017 at 7:25 PM, Kevin Grootendorst <
>>> Thanks for this feedback Jim.
>>> Would the current GeoMoose version 2.9.2 support this endeavor or have
>>> features/functions been deprecated since then?
>>> With respect to your second point, my client's GeoNetwork would not be
>>> harvesting data from other catalogs, only an internal database. I foresee
>>> less complexity in terms of needing mapfiles generated on-the-fly to deal
>>> with projection issues.
>>> In hindsight though, do you think that the GeoMoose - GeoNetwork
>>> connection was worth your time and effort? Or do you believe that it makes
>>> more sense just to keep the two applications separate? Given the time and
>>> effort involved, I'm torn between the viability and feasibility of this,
>>> versus some sort of alternate solution.
>>> Cheers,
>>> Kevin
>>> On Thu, Feb 2, 2017 at 10:46 AM, James Klassen <klassen.js at gmail.com>
>>> wrote:
>>>> I wrote an extension connected GeoMoose to a CSW server (GeoNetwork)
>>>> for a project maybe 5 years ago or so. I had intended to release it but
>>>> never got around to cleaning it up enough to not be project specific. It
>>>> would also take some work to bring it up to date with current GeoMoose.
>>>> It was a tab that searched the catalog and then presented the results
>>>> with options to view the metadata or if a WMS link was present in the
>>>> metadata, add the layer to the map. A download button would be possible if
>>>> it could be derived from the metadata, but don't remember if I had that
>>>> working.
>>>> Add to Map required some trickery:
>>>> 1) The Active/Visible layers extension was necessary to control the
>>>> layers added from CSW. The regular Catalog tab still works as normal but
>>>> didn't know anything about the new layers.
>>>> 2) (And this was the real stumbling block to me finishing the release.)
>>>> Because the CSW server was cataloging many off site resources, I had no
>>>> control over the WMS servers. As such many didn't support the projection
>>>> used by GeoMoose (at the only commonly available WMS projection was 4326
>>>> which looks horrible on screen) so I wrote a ruby-mapscript program that
>>>> generated a mapfile for MapServer on the fly (in RAM) that from the
>>>> metadata info would connect to the remote WMS, find the best projection
>>>> supoorted by the server, if necessary reproject it to the projection uses
>>>> by GeoMoose and create a local WMS server that GeoMoose would use.
>>>> On Feb 2, 2017 8:23 AM, "Kevin Grootendorst" <kgrootendorst at gmail.com>
>>>> wrote:
>>>> Dear list,
>>>> I'm interested in using GeoMOOSE to ssearch and display layers from
>>>> GeoNetwork. A user would be able to query GeoNetwork metadata from within
>>>> GeoMOOSE, then have the option to display metadata, add the layer to the
>>>> map, or download the layer.
>>>> I think I have to implement Catalog Web Services in GeoNetwork and have
>>>> GeoMOOSE connect to these web services. I assume I'll have to write a
>>>> JavaScript extension for GeoMOOSE, but JS is not my strength.
>>>> Does any one have any insight into how to develop this connection? I
>>>> found a post from years ago that confirmed that the connection is possible,
>>>> but there was no additional info.
>>>> Cheers,
>>>> Kevin
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170203/9efc7df7/attachment.html>
More information about the Geomoose-users
