[Geomoose-users] Identify with a https WMS source
James Klassen
klassen.js at gmail.com
Mon Feb 6 06:29:03 PST 2017
Why do you need those options? Generally,! disabling the certificate checks
isn't a good idea.
On Feb 5, 2017 8:45 PM, "Brent Fraser" <bfraser at geoanalytic.com> wrote:
Hi all,
To get identify.php to work when I specify a WMS map-source using https
(instead of the old and out-dated http), I had to add a couple of curl
options to identify.php around line 196:
curl_setopt($curlHandle, CURLOPT_SSL_VERIFYHOST, 0);
curl_setopt($curlHandle, CURLOPT_SSL_VERIFYPEER, 0);
Should I file an issue or is this already handled in 3.0?
And what's with hardcoding "INFO_FORMAT=application/vnd.ogc.gml" into the
request? Should we make that configurable in the map-source definition?
Thanks!
Best Regards,
Brent Fraser
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170206/df1cea2a/attachment.html>
More information about the Geomoose-users
