[Geomoose-users] Identify with a https WMS source
Brent Fraser
bfraser at geoanalytic.com
Mon Feb 6 12:22:36 PST 2017
Hey Jeff,
Good catch, mine was missing. But after copying the cert file from the
latest MS4W zip and restarting Apache, PHP curl still did not retrieve
the GML.
I may have to do a little debugging...
Best Regards,
Brent Fraser
On 2/6/2017 11:39 AM, Jeff McKenna wrote:
> Hi Brent,
> MS4W includes an important file for this, the CA certificate bundle,
> and Apache's httpd.conf points to it (see
> http://ms4w.com/README_INSTALL.html#k-certificates-for-https-with-wms-wfs-servers).
> However sometimes MS4W gets upgraded and that little file is
> forgotten in the release package (I believe this was missing in MS4W
> 3.1.4); the file is included in the recent MS4W 3.2.0 release. But if
> you ever notice anything missing in an MS4W, please file a ticket
> right away on that at http://ms4w.com/trac (otherwise that little file
> will be missed in the next release).
> -jeff
> On 2017-02-05 10:45 PM, Brent Fraser wrote:
>> Hi all,
>> To get identify.php to work when I specify a WMS map-source using
>> https (instead of the old and out-dated http), I had to add a couple of
>> curl options to identify.php around line 196:
>> curl_setopt($curlHandle, CURLOPT_SSL_VERIFYHOST, 0);
>> curl_setopt($curlHandle, CURLOPT_SSL_VERIFYPEER, 0);
>> Should I file an issue or is this already handled in 3.0?
>> And what's with hardcoding "INFO_FORMAT=application/vnd.ogc.gml" into
>> the request? Should we make that configurable in the map-source
>> definition?
>> Thanks!
More information about the Geomoose-users
