[Geomoose-users] MS4W version 3.2.2 available
James Klassen
klassen.js at gmail.com
Fri Jul 14 08:10:58 PDT 2017
Very cool. Thanks Jeff!
On Thu, Jul 13, 2017 at 11:12 AM, Jeff McKenna <
jmckenna at gatewaygeomatics.com> wrote:
> Hi all! See below for some good news, you'll be interested that the
> GeoMOOSE 3.0.0-beta is actually included as an option in the MS4W setup.exe
> installer, give it a try! :) I also listed GM3 on the download page at
> http://ms4w.com/download.html -jeff
> -------- Forwarded Message --------
> Hello everyone,
> MS4W version 3.2.2 is now available at http://www.ms4w.com This contains
> security releases of Apache, PHP, and upgrades to the MapServer 7.0.6 &
> GDAL 2.2.1 releases. Several changes were also made to libraries for
> performance improvements (such as libjpeg-turbo and SQLite). Several
> packages were upgraded for the installer including GeoMOOSE 3.0.0-beta (new
> backend engine, give it a try!), Mapbender 3.0.6.1 (now super fast),
> OpenLayers 4.2.0 (when you goto the OpenLayers examples page and search for
> "mapserver" you can find a local MS4W example). This a substantial MS4W
> release. Here is the full list of changes:
> - upgraded MapServer and MapScript (CSharp, Java, Python, PHP) to 7.0.6
> - upgraded GDAL to 2.2.1 (trac ticket 111)
> - upgraded PHP to 5.6.31 (trac ticket 122)
> - upgraded Apache to 2.4.27 (trac ticket 119)
> - enabled OPcache PHP extension for Mapbender performance (trac ticket
> 63)
> - built MapServer with support for Z geometry values (trac ticket 120)
> - updated cURL certificates bundle
> - rebuilt mod_fcgid
> - rebuilt Apache H264 Streaming Module
> - rebuilt MapCache
> - rebuilt TinyOWS
> - changed JPEG library to libjpeg-turbo (trac ticket 121)
> - upgraded libPNG support to 1.6.29
> - upgraded libTIFF support to 4.0.8 (trac ticket 114)
> - upgraded GeoTIFF support to SVN-trunk-20170623
> - rebuilt HDF4 support
> - upgraded HDF5 support to 1.10.1
> - upgraded PostgreSQL support to 9.6.3
> - upgraded MySQL support to 5.7.18
> - upgraded SQLite support to 3.19.3 (trac ticket 107)
> - rebuilt SpatiaLite support
> - upgraded OpenSSL support to 1.0.2l (trac ticket 116)
> - upgraded cURL support to 7.54.1
> - added curl.exe utility into /tools
> - rebuilt NetCDF support
> - upgraded Freetype support to 2.8
> - upgraded Cairo support to 1.14.10
> - rebuilt Poppler support
> - upgraded to Esri File Geodatabase 1.5 API support (trac ticket 109)
> - upgraded to Oracle SDK 12.2.0.1.0
> - upgraded PCRE support to 8.40
> - upgraded HarfBuzz support to 1.4.6
> - rebuilt libSVG support
> - rebuilt libSVG-Cairo support
> - upgraded Shapelib support to 1.4.0 (trac ticket 72)
> - rebuilt shp2tile utility
> - renamed Apache access and error log files
> Please note that (if you are using the .zip) your server must have the C++
> Redistributable installed on it beforehand: execute the local file
> /ms4w/tmp/vcredist_x86.exe
> Please don't be afraid to also provide feedback and requests through the
> MS4W tracker (so the comments and requests are not lost or forgotten):
> http://www.ms4w.com/trac/
> Thank you all for sharing your spatial information with MS4W.
> And happy MapServing!
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170714/e7f9ca54/attachment.html>
More information about the Geomoose-users
