[Geomoose-users] Error printing in GeoMOOSE 2.6
Mark Volz
MarkVolz at co.lyon.mn.us
Mon Mar 6 06:09:21 PST 2017
Tanya,
I am using GeoMOOSE 2.9.2 over MS4W 3.2.1. I have not moved the GeoMOOSE directory at all. All of my other services that I configured thus far (map printing etc) work fine.
local_settings.ini
; These are the default settings for working with MS4W
; Copy this to "local_settings.ini" for GeoMOOSE trunk to
; work with MS4W
[paths]
root=/ms4w/apps/geomoose2/maps/
mapserver_url=/cgi-bin/mapserv.exe
temp=/ms4w/tmp/ms_tmp/
Sincerely,
Mark Volz
Sent: Saturday, March 04, 2017 1:53 PM
To: Mark Volz <MarkVolz at co.lyon.mn.us>
Subject: Re: [Geomoose-users] Error printing in GeoMOOSE 2.6
I think if you are on windows MS4W you are going to want to make sure the paths in localsettings.ini have the drive letter and also the appropriate trailing slash at the end of the path.
just an idea, because I was also having printing problems, and it was the paths in that file that were my problem.
Tanya
On Wed, Feb 22, 2017 at 5:57 AM, Mark Volz <MarkVolz at co.lyon.mn.us<mailto:MarkVolz at co.lyon.mn.us>> wrote:
TC,
I did look at the local_settings.ini file. I think that file only would apply if I changed around the directory structure (where mapserver is, where the temp files are, and the root location of my .map files)
Thanks
Sincerely,
Mark Volz
-----Original Message-----
From: TC Haddad [mailto:tchaddad at gmail.com<mailto:tchaddad at gmail.com>]
Sent: Tuesday, February 21, 2017 8:42 PM
To: Mark Volz <MarkVolz at co.lyon.mn.us<mailto:MarkVolz at co.lyon.mn.us>>
maybe local_setting.ini?
On Tue, Feb 21, 2017 at 1:47 PM, Mark Volz <MarkVolz at co.lyon.mn.us<mailto:MarkVolz at co.lyon.mn.us>> wrote:
> Hello,
> I changed the server, port, and url that one of my GeoMOOSE sites is
> using and the print functionality is no longer working. Everything
> else seems fine. I imagine that I may have missed changing a setting
> somewhere in one of the configuration files, but for all I know
> something else could be going wrong.
> Here is the error message that I got:
> Error Calling the server:
> Error: Unable to load php/print.php status:0
> Here are some of the files the I updated for the new server. Let me
> know if I am missing a file:
> Apache\conf\httpd.conf
> Geomoose2\Conf\settings.ini
> Geomoose2\Conf\mapbook.xml
> Thank You!
> Sincerely,
> Mark Volz
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170306/5f3b9707/attachment.html>
More information about the Geomoose-users
