[Geomoose-users] Issues with buffer lines not displaying with select features functionality and feature reports - GM 2.9.2
Brent Fraser
bfraser at geoanalytic.com
Tue Mar 14 15:38:17 PDT 2017
Feature Reports are very special (and I don't think the
feature_report.php has been changed for 2.9.2). What specifically do
you see (or don't see) when you try yo do an Identify->Feature Report?
Best Regards,
Brent Fraser
On 3/14/2017 9:23 AM, Mark Volz wrote:
> Brent,
> Thank you for your reply. It seems your thread from 2.7.1 and 2.8
> dealt with issues when the projection the data layer, mapserver map
> file, and geoMOOSE openlayers do not match. In my case everything
> should be in the same projection, which is Lyon County Coordinates
> 103749. I think I did everything necessary to add my own projection,
> however it may be possible I missed a step.
> Here is what I did to add my own projection:
> 1)Added a definition for <103749> to C:\ms4w\proj\nad\espg
> 2)Modified local_settings.ini to reference EPSG:103749, and the fields
> used for mailing labels
> 3)Updated C:\ms4w\apps\geomoose2\conf\feature_report\parcel.xml to
> reference my mailing labels fields
> 4)Updated the extent and projection in
> C:\ms4w\apps\geomoose2\htdocs\geomoose\config.js
> 5)Updated the extent and projection in
> C:\ms4w\apps\geomoose2\conf\mapbook.xml
> 6)Added EPSG103749.js to C:\ms4w\apps\geomoose2\htdocs\projections
> 7)Added EPSG103749.js to
> C:\ms4w\apps\geomoose2\htdocs\libs\proj4js\lib\defs as well
> 8)Included script type="text/javascript"
> src="projections/EPSG103749.js"></script> in geomoose.html
> 9)Set the mapserver .map file and all of the layers to ‘init=epsg:103749’
> Everything appears to work except for feature reports and the polygon
> outline displaying the buffer on select features.
> Thank You
> Sincerely,
> *Mark Volz, GISP***
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Monday, March 13, 2017 6:26 PM
> *To:* Mark Volz <MarkVolz at co.lyon.mn.us>; geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] Issues with buffer lines not
> 2.9.2
> Mark,
> I did some testing some time ago on v2.7.1 and v2.8. The behaviors
> I found may be related to what you are seeing. Have a look at the
> thread
> http://lists.osgeo.org/pipermail/geomoose-users/2015-July/005735.html
> Best Regards,
> Brent Fraser
> On 3/13/2017 1:36 PM, Mark Volz wrote:
> Hello,
> I am still having issues trying to get the feature report and
> buffer on selected features functionality to work on my map. I am
> specifically wondering if anyone has had any success using a
> projection other than EPSG:3857.
> Buffers:
> At GeoMOOSE 2.9.2 the select feature function uses query.php.
> However on an older 2.6 application I noticed the select feature
> function used select.php instead.
> *Do I need select.php to draw buffers in the select feature function?
> *select.php attempts to create a spatial lite .db file. However,
> I cannot get this file to open in Mapserver
> *I cannot get the mailing labels to work using select.php
> Feature Reports:
> I am also having issues with the feature report functionality. Is
> the feature report dependent on a certain projection?
> Anyways, if anyone has had any luck configuring GM 2.9.2 with a
> different projection please let me know.
> Thank You!
> Sincerely,
> Mark Volz
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170314/c15bc46a/attachment.html>
More information about the Geomoose-users
