[Geomoose-users] WFS in GM3
Dan Little
theduckylittle at gmail.com
Wed Sep 6 05:11:11 PDT 2017
Okay, I'm back at it.
I suspect it's due to how MapServer treats the *order* of the projections
in the WEB definition. Can you post that?
On Mon, Aug 28, 2017 at 4:23 PM, TC Haddad <tchaddad at gmail.com> wrote:
> Yep, the WFS draws nicely from the GML response, so in that way,
> projections are all happy...
> On Mon, Aug 28, 2017 at 2:03 PM, Dan Little <theduckylittle at gmail.com>
> wrote:
>> Does the WFS layer *draw* on the map? (Define some styles,and then add a
>> catalog item for it.)
>> I suspect a projections issue as well. The reason the query happens in
>> 4326 is due to some MapServer projection bugs that I had found while doing
>> the dev work. The easiest way to handle it was to use 4326 for the query.
>> On Mon, Aug 28, 2017 at 3:32 PM, TC Haddad <tchaddad at gmail.com> wrote:
>>> I'm working my way through setting up GM3 with some local parcel data,
>>> and am having issues with the portions that use WFS. Here's what's
>>> happening:
>>> - local data draws fine
>>> - Identify uses WMS GetFeatureInfo, and works fine
>>> - Search and Select both use WFS and seem to generate valid queries.
>>> They do not return an error when used, but do return an empty set of
>>> results.
>>> troubleshooting:
>>> - Search: figured out that there was a hard-coded field name in
>>> search.js that wasn't mentioned in the docs, but after fixing that, I'm
>>> still not getting any results from search...
>>> - Select: seems to be passing valid coordinates in 4326 to the WFS. The
>>> data is in 3857. The data is drawing correctly so I'm assuming the map file
>>> is fine, but no results come back, so wondering about projection issues for
>>> this one...
>>> Any ideas where else I can look for issues?
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170906/8221efe2/attachment.html>
More information about the Geomoose-users
