[Geomoose-users] WFS in GM3
Dan Little theduckylittle at gmail.com
Wed Sep 6 14:43:43 PDT 2017
Can you try commenting out wfs_srs and copying all the projection codes
into the ows_srs line? MapServer has some really obnoxious quirks WRT how
the projections are defined for the OGC services.
On Wed, Sep 6, 2017 at 12:43 PM, TC Haddad <tchaddad at gmail.com> wrote:
> WEB
> METADATA
> 'ows_title' 'taxlots'
> 'ows_srs' 'EPSG:3857'
> 'ows_enable_request' '*'
> 'ows_onlineresource' 'http://www.geomoose.org'
> 'wfs_srs' 'EPSG:2269 EPSG:4326 EPSG:3857 EPSG:900913'
> 'wms_feature_info_mime_type' 'application/json'
> 'wfs_getfeature_formatlist' 'gml,geojson'
> END
> END
> On Wed, Sep 6, 2017 at 5:11 AM, Dan Little <theduckylittle at gmail.com>
> wrote:
>> Okay, I'm back at it.
>> I suspect it's due to how MapServer treats the *order* of the projections
>> in the WEB definition.  Can you post that?
>> On Mon, Aug 28, 2017 at 4:23 PM, TC Haddad <tchaddad at gmail.com> wrote:
>>> Yep, the WFS draws nicely from the GML response, so in that way,
>>> projections are all happy...
>>> On Mon, Aug 28, 2017 at 2:03 PM, Dan Little <theduckylittle at gmail.com>
>>> wrote:
>>>> Does the WFS layer *draw* on the map? (Define some styles,and then add
>>>> a catalog item for it.)
>>>> I suspect a projections issue as well. The reason the query happens in
>>>> 4326 is due to some MapServer projection bugs that I had found while doing
>>>> the dev work.  The easiest way to handle it was to use 4326 for the query.
>>>> On Mon, Aug 28, 2017 at 3:32 PM, TC Haddad <tchaddad at gmail.com> wrote:
>>>>> I'm working my way through setting up GM3 with some local parcel data,
>>>>> and am having issues with the portions that use WFS. Here's what's
>>>>> happening:
>>>>> - local data draws fine
>>>>> - Identify uses WMS GetFeatureInfo, and works fine
>>>>> - Search and Select both use WFS and seem to generate valid queries.
>>>>> They do not return an error when used, but do return an empty set of
>>>>> results.
>>>>> troubleshooting:
>>>>> - Search: figured out that there was a hard-coded field name in
>>>>> search.js that wasn't mentioned in the docs, but after fixing that, I'm
>>>>> still not getting any results from search...
>>>>> - Select: seems to be passing valid coordinates in 4326 to the WFS.
>>>>> The data is in 3857. The data is drawing correctly so I'm assuming the map
>>>>> file is fine, but no results come back, so wondering about projection
>>>>> issues for this one...
>>>>> Any ideas where else I can look for issues?
>>>>> _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170906/32e07438/attachment.html>
More information about the Geomoose-users mailing list
