[Geomoose-users] GM3: Different Projections, securing underlying data?
Mark Volz
MarkVolz at co.lyon.mn.us
Wed Sep 27 12:35:25 PDT 2017
Dan and Jim,
Thank you for your reply.
Regarding projections, I would still like to use county coordinates for the x/y status bar, underlying data, air photo background, etc. I have no desire to use Google or Mapnik boundaries. Therefore I would like to continue using my county coordinates if possible. Is there a way that I can verify which version of Mapserver / MS4W has the projection bug so that I can avoid that version of Mapserver / MS4w if I choose to use my own projection?
Regarding sharing data through WMS, WFS, and GeoJson. Our county does not have an “Open Data” Policy yet. Therefore I think I should do my due diligence to try to protect users from downloading the parcels in a vector format through an open WFS or GeoJSON endpoint – even if it is just the outline and Parcel Identification Number. So it sounds like my choices right now are 1) Adopt an Open data Policy. 2) Use GeoMOOSE 3.x, but without the cool features, or 3) Use GeoMOOSE 2.x. Is that correct? If so perhaps there might be more interest in adopting an open data policy.
Thank You!
Sincerely,
Mark Volz, GISP
From: Dan Little [mailto:theduckylittle at gmail.com]
Sent: Friday, September 22, 2017 6:27 PM
To: Jim Klassen <klassen.js at gmail.com>
Cc: Mark Volz <MarkVolz at co.lyon.mn.us>; GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
Subject: Re: [Geomoose-users] GM3: Different Projections, securing underlying data?
Jim hit the nail on the head.
Also, it's important to keep in mind you were ALWAYS publishing that data, as mapserver had access to it via through WMS AND its own protocols. It is best to limit which attributes are published if you're worried about privacy protection.
On Sep 22, 2017 18:23, "James Klassen" <klassen.js at gmail.com<mailto:klassen.js at gmail.com>> wrote:
A quick answer from the top of my head.
1) No, but it works around a bug in some versions of MapServer and generally makes life a little simpler. The data can still be stored in your favorite projection and it gets reprojected on the fly for the map.
2) GeoMoose 3 will display and identify features on WMS layers but it needs access to the vector features (WFS or GeoJSON) to do a lot of the cool new stuff (client side buffering, querying based on features in a layer, and IIRC the results grid to name a few).
Some options:
* Not allow vector access and live with the reduced feature set
* Allow vector access but filter it with MapServer to limit what features/attributes/etc. is exposed.
On Fri, Sep 22, 2017 at 3:38 PM, Mark Volz <MarkVolz at co.lyon.mn.us<mailto:MarkVolz at co.lyon.mn.us>> wrote:
Hello,
I am curious about a couple things regarding GeoMOOSE 3.
First,
I have seen several emails referencing projection 4326. Is that the only supported projection or can we use our own?
Second,
Unlike GeoMOOSE 2.x, It appears that GeoMOOSE 3 relies heavily on OGC and GeoJSON. Does this imply that we have to have our underlying data exposed on a web server that could be accessed by clients other than GeoMOOSE, or can we still keep the underlying data private?
Thank You!
Sincerely,
Mark Volz, GISP
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170927/d194ffee/attachment.html>
More information about the Geomoose-users
