[Geomoose-users] Template / Results Issues
Dan Little
theduckylittle at gmail.com
Wed Feb 7 06:47:41 PST 2018
Yes, please post up the Mapbook snippet of the affected code and, if
possible, a snippet of the data returned from the WFS request.
Jeff, were you consistently getting that error with the international
characters dataset? If so, I should really test that.
On Wed, Feb 7, 2018 at 8:45 AM, Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> Hi Tanya,
> I've tested with the included "Test International Characters" layer that
> is included in the packaged mapbook.xml by default, using MS4W version 3.2.3
> I was able to get your exact same error through an identify on that layer.
> I fixed this by making sure to specify "{{ properties.FIELDNAME }}" in my
> mapbook.xml (at first I had just "{{ FIELDNAME }}"). Here is the working
> section: https://gist.github.com/anonymous/945d1987942ff34fbc53d253c8
> cd20b3
> Maybe your issue is similar.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 2018-02-07 2:27 AM, TC Haddad wrote:
>> hi all,
>> I've just been testing 3.1 with some local data, and have a weird issue
>> with displaying the results from Identify, Select, and Search.
>> I'm getting correct number of records and fields returning for each item
>> clicked, selected, or found via a search, but result contents all display
>> as "???".
>> example: http://bit.ly/2FS8ySS
>> I feel like I'm missing something really basic - any ideas why my
>> templates aren't correctly populating?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20180207/a08ca3ee/attachment.html>
More information about the Geomoose-users
