[Geomoose-users] debugging mapserver WFS layer search
karsten karsten at terragis.net
Fri Jan 5 09:52:51 PST 2018
Thanks Eli.
I have set the MS debug = 5 in the map file and also enabled postgresql
logging.
In the mapserver log I get "No matching record(s) found":
[Fri Jan 05 18:32:59 2018].645000 msWFSParseRequest(): WFS post request:
<GetFeature xmlns="http://www.opengis.net/wfs" service="WFS" version="1.1.0"
outputFormat="text/xml; subtype=gml/2.1.2"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><Query
typeName="ms:flurstueck_wfs" srsName="EPSG:4326"><Filter
xmlns="http://www.opengis.net/ogc"><PropertyIsLike wildCard="*"
singleChar="." escapeChar="!"
matchCase="false"><PropertyName>lagebezeichnung</PropertyName><Literal>*Plat
ten*</Literal></PropertyIsLike></Filter></Query></GetFeature>
[Fri Jan 05 18:32:59 2018].728000 FLTLayerApplyPlainFilterToLayer():
("[lagebezeichnung]" ~* ".*Platten.*"),
rect=-7.34596005204958,60.6642900785306,6.38576697281957,66.6415244533575
[Fri Jan 05 18:32:59 2018].758000 msQueryByFilter(): Search returned no
results. No matching record(s) found.
and in the postgresql log I
PST ERROR:  syntax error at or near "*" at character 514 PST STATEMENT:
SELECT gml_id, identifier, beginnt, advstandardmodell, anlass, land,
	       gemarkungsnummer, zaehler, flurstueckskennzeichen, gemarkung,
	       amtlicheflaeche, flurnummer, abweichenderrechtszustand,
rechtsbehelfsverfahren,
	       zeitpunktderentstehung, regierungsbezirk, kreis, gemeinde,
istgebucht,
	       zeigtauf, weistauf, nenner, zweifelhafterflurstuecksnachweis,
	       ogc_fid, fid, gid, wkb_geometry, fc, lagebezeichnung,
eigentuemer
	  FROM public.gm_ax_flurstueck_geo where lagebezeichnung ilike
*Platten*;
This seems to hint to that the query send via geomoose seems to have a
problem with the syntax. When I change it to ... FROM
public.gm_ax_flurstueck_geo where lagebezeichnung ilike '%Platten%'; and run
manually it is working ...
Not sure if there is a work around or other config for the postgis layer
that I can use in Geomoose ...
Karsten
-----Original Message-----
Sent: Freitag, 5. Januar 2018 18:08
To: karsten
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] debugging mapserver WFS layer search
Hi Karsten,
I'm not sure on this but have a few troubleshooting ideas that might help.
On Fri, Jan 5, 2018 at 7:53 AM, karsten <karsten at terragis.net> wrote:
> Hi All,
> I have configured my first Geomoose v 3 pilot project and got all working
except a MapServer WFS layer search on a PostGIS layer. I am using ms4w v
3.2.3  and the app package geomoose 3.1. I have successfully added a
firestation WFS search to the desktop demo
http://localhost/gm3/desktop/index.html following  the instructions at
http://geomoose.github.io/gm3/howto/add-search.html .
> Now I have used MapServer WMS for many years but this is the first time I
am using WFS; so am a bit lost of how to debug my own custom layers search
in Geomoose.
> In a copy of the desktop app I added my own data and so on but the search
on one parcel layer I have added (a MapServer WFS layer drawn from PostGIS)
returns no errors but empty gml results.
> The request I can see is
> http://localhost/cgi-bin/mapserv.exe?MAP=c:/data/mapfiles/mechernich.m
> ap&typename=ms:flurstueck_wfs
> plus the post params
> MAP c:/data/mapfiles/mechernich.map
> typename     ms:flurstueck_wfs
> version="1.1.0" outputFormat="text/xml; subtype=gml/2.1.2"
> >*Auf*</Literal></PropertyIsLike></Filter></Query></GetFeature>
> The response gives me an empty bounding box and feature collection (when
there are many objects that should be found using the string "Auf" - tried
it with a postgres SQL query that gave me > 2200 results):
You can turn on Postgresql logging to see what query is actually run on
Postgresql from MapServer/GeoMoose.  Then read the logs and run that query
via psql or PGAdmin to see what it returns.  That lets you know whether the
query getting passed in is bad or the correct results are returned and not
properly handled by MapServer/GeoMoose.
https://stackoverflow.com/questions/722221/how-to-log-postgresql-queries#722
236
> <?xml version='1.0' encoding="UTF-8" ?> <wfs:FeatureCollection
>    xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>    xmlns:wfs="http://www.opengis.net/wfs"
>    xmlns:gml="http://www.opengis.net/gml"
>    xmlns:ogc="http://www.opengis.net/ogc"
http://schemas.opengis.net/wfs/1.1.0/WFS-basic.xsd
http://localhost/cgi-bin/mapserv?map=C:/data/mapfiles/mechernich.map&SER
VICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=ms:f
lurstueck_wfs&OUTPUTFORMAT=XMLSCHEMA">
>    <gml:boundedBy>
>       <gml:null>missing</gml:null>
>    </gml:boundedBy>
> </wfs:FeatureCollection>
> I have tried to include all that is needed in the mapsertver layers see
below (even changed the data tag to a sub select to make sure all atributes
are retrieved for sure ...
> Would anyone have suggestions how to debug this ?
> Cheers
> Karsten
> Karsten Vennemann
> Principal
> Terra GIS LTD
> www.terragis.net
> ------------------- in map file  ---------------
>   LAYER
>     CONNECTION "dbname='gisme' host=localhost port=5432 user='postgres'
password='postgres' sslmode=disable"
>     CONNECTIONTYPE POSTGIS
>     DATA 'wkb_geometry FROM (select * from
"public"."gm_ax_flurstueck_geo") as foo USING UNIQUE fid USING srid=25832'
>     EXTENT 324008.5625 5598582 343287.6875 5614541
Good that you have EXTENT on your PostGIS layer.  That can be required.
Reviewing the mapbook.xml configuration for search might be helpful too.
Best regards, Eli
>     METADATA
>       "gml_include_items" "all"
>       "ows_extent" "324008.5625 5598582.0 343287.6875 5614541.0"
>       "ows_srs" "EPSG:25832 EPSG:3857 EPSG:900913 EPSG:4326"
>       "ows_title" "flurstueck_wfs"
>       "wms_bbox_extended" "true"
>       "wfs_title"         "flusstuecke_wfs" ##REQUIRED
>       "gml_featureid"     "ogc_fid" ## REQUIRED
>       "wfs_enable_request" "*"
>       'ows_srs' 'EPSG:25832 EPSG:4326 EPSG:3857 EPSG:900913'
>       'wfs_srs' 'EPSG:25832 EPSG:4326 EPSG:3857 EPSG:900913'
>       'wms_feature_info_mime_type' 'application/json'
>    END # METADATA
>     TEMPLATE 'dummy'
>     NAME "flurstueck_wfs"
>     PROJECTION
>       "init=epsg:25832"
>     END # PROJECTION
>     STATUS OFF
>     TILEITEM "location"
>     TYPE POLYGON
>     UNITS METERS
>     CLASS
>       NAME "Flurstueck"
>       STYLE
>         COLOR 249 250 255
>         OPACITY 0
>       END # STYLE
>       STYLE
>         OUTLINECOLOR 187 142 142
>         WIDTH 0.982677
>       END # STYLE
>     END # CLASS
>   END # LAYER
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
