[Geomoose-users] Using GM3 on Linux
Ron Wardenier GeoConsult
ron at rwgc.nl
Sun Jan 21 22:08:46 PST 2018
Thanks Dan! That got me on track again and I now have a running GeoMoose :)
Cheers,
Ron
> Op 20 jan. 2018 om 15:20 heeft Dan Little <theduckylittle at gmail.com> het volgende geschreven:
> Hi Ron,
> This has come up before. The entire development team uses Linux actually. It might be helpful to look at the EC2 deployment instructions. You can skip the bits about setting up the server but the rest should be helpful:
> - http://geomoose.github.io/gm3/quickstart-ec2.html
> Cheers!
>> On Jan 20, 2018 05:35, "Ron Wardenier GeoConsult" <ron at rwgc.nl> wrote:
>> Dear all,
>> Let me compliment you on the GeoMoose version 3 stack and features. Very promising.
>> I'm trying to set GM3 up on Linux but it seems the current release is very centred on using MS4W. So far I have not been successful in getting a working version on localhost. I'm not sure where to put the demo dataset and the app can't find the file config.js. The config.js.example just contains a reference to a (local) MapServer and I can't find any examples of using external WMS sources.
>> Is version 3 not ready for what I am trying to do or isn't it intended to be used separately from MS4W?
>> Thank you,
>> Ron Wardenier
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20180122/19c40801/attachment.html>
More information about the Geomoose-users
