[Geomoose-users] Printing using mapcache - older version of GeoMOOSE
Dan Little theduckylittle at gmail.com
Mon Jan 22 06:14:32 PST 2018
- There was no code written in the 2.X series to handle the printing of
tiled datasets.  No one ever took up the mantle and no sponsorship ever
came in for the feature.
- I would disable tiling.  Generally speaking, you'll get close to the same
performance out of a well setup GeoTiff. MapServer can render them very
quickly and the data file size for a county or even multi-county area isn't
so large as to create too many issues.
- Yes, this issue has been resolved in GeoMoose 3.X.  And by default
GeoMoose 3.X will use WFS to execute it's queries.  MapServer offers the
ability to limit the data available over WFS, regardless of whether the
parcels are 'open' or not.  The same is true of GeoMoose 2.X, the data that
can be returned by the PHP scripts is the same data that can be returned by
WFS and vice-versa.  The differences is that GM 3.X targets a standard
instead of our own DIY request structure.
On Fri, Jan 19, 2018 at 11:54 AM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> I am currently using mapcache tiles for fast viewing of air photos.
> However the tiles do not print similar to issue 39.
> https://github.com/geomoose/geomoose/issues/39.  I am using GeoMOOSE 2.4
> and 2.6.
> I was wondering:
> ·         Has anyone found a workaround for this issue?
> ·         Should I just disable tiling and have mapcache run as a WFS?
> ·         Has this issue been resolved in new versions of GeoMOOSE?
> However, I was under the impression that some of the features require WFS
> to work well.  At this time our parcels are not open therefore upgrading
> might be difficult.
> Please let me know if you have any opinions as to how I can move forward.
> Thank You!
> Sincerely,
> *Mark Volz, GISP*
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20180122/528f11d3/attachment.html>
More information about the Geomoose-users mailing list
