[Geomoose-users] debugging mapserver WFS layer search
Dan Little
theduckylittle at gmail.com
Tue Jan 30 18:24:51 PST 2018
PR is available to address the issue on GitHub.
On Mon, Jan 8, 2018 at 11:23 AM, Eli Adam <eadam at co.lincoln.or.us> wrote:
> On Fri, Jan 5, 2018 at 9:52 AM, karsten <karsten at terragis.net> wrote:
> > Thanks Eli.
> > I have set the MS debug = 5 in the map file and also enabled postgresql
> > logging.
> > In the mapserver log I get "No matching record(s) found":
> > [Fri Jan 05 18:32:59 2018].645000 msWFSParseRequest(): WFS post request:
> > <GetFeature xmlns="http://www.opengis.net/wfs" service="WFS"
> version="1.1.0"
> > outputFormat="text/xml; subtype=gml/2.1.2"
> > xsi:schemaLocation="http://www.opengis.net/wfs
> > http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
> > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><Query
> > typeName="ms:flurstueck_wfs" srsName="EPSG:4326"><Filter
> > xmlns="http://www.opengis.net/ogc"><PropertyIsLike wildCard="*"
> > singleChar="." escapeChar="!"
> > matchCase="false"><PropertyName>lagebezeichnung</
> PropertyName><Literal>*Plat
> > ten*</Literal></PropertyIsLike></Filter></Query></GetFeature>
> > [Fri Jan 05 18:32:59 2018].728000 FLTLayerApplyPlainFilterToLayer():
> > ("[lagebezeichnung]" ~* ".*Platten.*"),
> > rect=-7.34596005204958,60.6642900785306,6.38576697281957,66.
> 6415244533575
> > [Fri Jan 05 18:32:59 2018].758000 msQueryByFilter(): Search returned no
> > results. No matching record(s) found.
> > and in the postgresql log I
> > PST ERROR: syntax error at or near "*" at character 514 PST STATEMENT:
> > SELECT gml_id, identifier, beginnt, advstandardmodell, anlass, land,
> > gemarkungsnummer, zaehler, flurstueckskennzeichen,
> gemarkung,
> > amtlicheflaeche, flurnummer, abweichenderrechtszustand,
> > rechtsbehelfsverfahren,
> > zeitpunktderentstehung, regierungsbezirk, kreis, gemeinde,
> > istgebucht,
> > zeigtauf, weistauf, nenner, zweifelhafterflurstuecksnachwe
> is,
> > ogc_fid, fid, gid, wkb_geometry, fc, lagebezeichnung,
> > eigentuemer
> > FROM public.gm_ax_flurstueck_geo where lagebezeichnung ilike
> > *Platten*;
> > This seems to hint to that the query send via geomoose seems to have a
> > problem with the syntax. When I change it to ... FROM
> > public.gm_ax_flurstueck_geo where lagebezeichnung ilike '%Platten%'; and
> run
> > manually it is working ...
> > Not sure if there is a work around or other config for the postgis layer
> > that I can use in Geomoose ...
> I opened an issue for discussion here,
> https://github.com/geomoose/gm3/issues/279. That also suggests where
> to look if you want to fiddle with it.
> Best regards, Eli
> > Karsten
> > -----Original Message-----
> > From: Eli Adam [mailto:eadam at co.lincoln.or.us]
> > Sent: Freitag, 5. Januar 2018 18:08
> > To: karsten
> > Cc: geomoose-users at lists.osgeo.org
> > Subject: Re: [Geomoose-users] debugging mapserver WFS layer search
> > Hi Karsten,
> > I'm not sure on this but have a few troubleshooting ideas that might
> help.
> > On Fri, Jan 5, 2018 at 7:53 AM, karsten <karsten at terragis.net> wrote:
> >> Hi All,
> >> I have configured my first Geomoose v 3 pilot project and got all
> working
> > except a MapServer WFS layer search on a PostGIS layer. I am using ms4w v
> > 3.2.3 and the app package geomoose 3.1. I have successfully added a
> > firestation WFS search to the desktop demo
> > http://localhost/gm3/desktop/index.html following the instructions at
> > http://geomoose.github.io/gm3/howto/add-search.html .
> >> Now I have used MapServer WMS for many years but this is the first time
> I
> > am using WFS; so am a bit lost of how to debug my own custom layers
> search
> > in Geomoose.
> >> In a copy of the desktop app I added my own data and so on but the
> search
> > on one parcel layer I have added (a MapServer WFS layer drawn from
> PostGIS)
> > returns no errors but empty gml results.
> >> The request I can see is
> >> http://localhost/cgi-bin/mapserv.exe?MAP=c:/data/mapfiles/mechernich.m
> >> ap&typename=ms:flurstueck_wfs
> >> plus the post params
> >> MAP c:/data/mapfiles/mechernich.map
> >> typename ms:flurstueck_wfs
> >> version="1.1.0" outputFormat="text/xml; subtype=gml/2.1.2"
> >> matchCase="false"><PropertyName>lagebezeichnung</PropertyName><Literal
> >> >*Auf*</Literal></PropertyIsLike></Filter></Query></GetFeature>
> >> The response gives me an empty bounding box and feature collection (when
> > there are many objects that should be found using the string "Auf" -
> tried
> > it with a postgres SQL query that gave me > 2200 results):
> > You can turn on Postgresql logging to see what query is actually run on
> > Postgresql from MapServer/GeoMoose. Then read the logs and run that
> query
> > via psql or PGAdmin to see what it returns. That lets you know whether
> the
> > query getting passed in is bad or the correct results are returned and
> not
> > properly handled by MapServer/GeoMoose.
> > https://stackoverflow.com/questions/722221/how-to-log-
> postgresql-queries#722
> > 236
> >> <?xml version='1.0' encoding="UTF-8" ?> <wfs:FeatureCollection
> >> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
> >> xmlns:wfs="http://www.opengis.net/wfs"
> >> xmlns:gml="http://www.opengis.net/gml"
> >> xmlns:ogc="http://www.opengis.net/ogc"
> > http://schemas.opengis.net/wfs/1.1.0/WFS-basic.xsd
> > http://localhost/cgi-bin/mapserv?map=C:/data/mapfiles/
> mechernich.map&SER
> > VICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&
> TYPENAME=ms:f
> > lurstueck_wfs&OUTPUTFORMAT=XMLSCHEMA">
> >> <gml:boundedBy>
> >> <gml:null>missing</gml:null>
> >> </gml:boundedBy>
> >> </wfs:FeatureCollection>
> >> I have tried to include all that is needed in the mapsertver layers see
> > below (even changed the data tag to a sub select to make sure all
> atributes
> > are retrieved for sure ...
> >> Would anyone have suggestions how to debug this ?
> >> Cheers
> >> Karsten
> >> Karsten Vennemann
> >> Principal
> >> Terra GIS LTD
> >> www.terragis.net
> >> ------------------- in map file ---------------
> >> LAYER
> >> CONNECTION "dbname='gisme' host=localhost port=5432 user='postgres'
> > password='postgres' sslmode=disable"
> >> CONNECTIONTYPE POSTGIS
> >> DATA 'wkb_geometry FROM (select * from
> > "public"."gm_ax_flurstueck_geo") as foo USING UNIQUE fid USING
> srid=25832'
> >> EXTENT 324008.5625 5598582 343287.6875 5614541
> > Good that you have EXTENT on your PostGIS layer. That can be required.
> > Reviewing the mapbook.xml configuration for search might be helpful too.
> > Best regards, Eli
> >> METADATA
> >> "gml_include_items" "all"
> >> "ows_extent" "324008.5625 5598582.0 343287.6875 5614541.0"
> >> "ows_srs" "EPSG:25832 EPSG:3857 EPSG:900913 EPSG:4326"
> >> "ows_title" "flurstueck_wfs"
> >> "wms_bbox_extended" "true"
> >> "wfs_title" "flusstuecke_wfs" ##REQUIRED
> >> "gml_featureid" "ogc_fid" ## REQUIRED
> >> "wfs_enable_request" "*"
> >> 'ows_srs' 'EPSG:25832 EPSG:4326 EPSG:3857 EPSG:900913'
> >> 'wfs_srs' 'EPSG:25832 EPSG:4326 EPSG:3857 EPSG:900913'
> >> 'wms_feature_info_mime_type' 'application/json'
> >> END # METADATA
> >> TEMPLATE 'dummy'
> >> NAME "flurstueck_wfs"
> >> PROJECTION
> >> "init=epsg:25832"
> >> END # PROJECTION
> >> STATUS OFF
> >> TILEITEM "location"
> >> TYPE POLYGON
> >> UNITS METERS
> >> CLASS
> >> NAME "Flurstueck"
> >> STYLE
> >> COLOR 249 250 255
> >> OPACITY 0
> >> END # STYLE
> >> STYLE
> >> OUTLINECOLOR 187 142 142
> >> WIDTH 0.982677
> >> END # STYLE
> >> END # CLASS
> >> END # LAYER
> >> _______________________________________________
> >> Geomoose-users mailing list
> >> Geomoose-users at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20180130/e5dd01ea/attachment.html>
More information about the Geomoose-users
