[Geomoose-users] Highlight Parcel and runtime substitution
Dan Little
theduckylittle at gmail.com
Wed Nov 28 07:47:04 PST 2018
Hi Scott,
Is this a GeoMoose 2.9-based application? Looks like it if you're using
"GeoMOOSE...".
Check out query.php and the various services that use it. You should be
able to either make your own derivative version of the service, or tweak
the query.php input parameters to get the result you want using you mapbook.
Cheers.
On Wed, Nov 28, 2018 at 8:19 AM Colas, Scott <Scott.Colas at ct.gov> wrote:
> Hello All,
> I have a service that does a search for a project. My goal is to zoom to
> this project and highlight. I can zoom to this project using GeoMOOSE.zoomToPointsList,
> but I cannot highlight the area.
> In my map file I am using filterItem and filter.
> How do I send my variable from a service to a map file so I can filter on
> this variable?
> LAYER
> INCLUDE "../../db_connection"
> DATA "geometry3857 FROM [ASSETS].[ProjectWorkAreas] USING UNIQUE
> AreaID USING SRID=3857"
> PROCESSING "NATIVE_FILTER=([IsProposed] = 0)"
> LABELITEM "ProjectNumber"
> CLASSITEM "PROJ_CURRENT_PHASE"
> NAME "LocalhProjectPolygons"
> TYPE POLYGON
> VALIDATION
> "PROJECTNUM" "[0-9]+"
> END
> FILTERITEM "ProjectNumber"
> FILTER "%PROJECTNUM%"
> CLASS
> NAME "05 Construction"
> EXPRESSION "05_Construction"
> TEXT "%PROJECTNUM%"
> LABEL
> MAXSCALEDENOM 28000
> FONT "vera_sans"
> SIZE 10
> ALIGN CENTER
> COLOR 255 0 0
> Thank you,
> -Scott
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20181128/3c26fa07/attachment.html>
More information about the Geomoose-users
