[Geomoose-users] Highlight Parcel and runtime substitution
Dan Little
theduckylittle at gmail.com
Wed Nov 28 12:20:37 PST 2018
Hi Scott,
This sounds like you're trying to do a special version of GeoMoose's
search. I think if you look at the parcels mapfile and the way query.php is
configured for search you'll be able to make some small changes to your
mapfile, configure a new service that users query.php, and doing everything
you want!
Cheers.
On Wed, Nov 28, 2018 at 2:19 PM Colas, Scott <Scott.Colas at ct.gov> wrote:
> Thanks Dan,
> After tweaking the parameters in query.php will my parameter be available
> in my map file so I can filter on the parameter?
> -Scott
> *From:* Dan Little [mailto:theduckylittle at gmail.com]
> *Sent:* Wednesday, November 28, 2018 10:47 AM
> *To:* Colas, Scott
> *Cc:* GeoMOOSE Users List
> *Subject:* Re: [Geomoose-users] Highlight Parcel and runtime substitution
> Hi Scott,
> Is this a GeoMoose 2.9-based application? Looks like it if you're using
> "GeoMOOSE...".
> Check out query.php and the various services that use it. You should be
> able to either make your own derivative version of the service, or tweak
> the query.php input parameters to get the result you want using you mapbook.
> Cheers.
> On Wed, Nov 28, 2018 at 8:19 AM Colas, Scott <Scott.Colas at ct.gov> wrote:
> Hello All,
> I have a service that does a search for a project. My goal is to zoom to
> this project and highlight. I can zoom to this project using GeoMOOSE.zoomToPointsList,
> but I cannot highlight the area.
> In my map file I am using filterItem and filter.
> How do I send my variable from a service to a map file so I can filter on
> this variable?
> LAYER
> INCLUDE "../../db_connection"
> DATA "geometry3857 FROM [ASSETS].[ProjectWorkAreas] USING UNIQUE
> AreaID USING SRID=3857"
> PROCESSING "NATIVE_FILTER=([IsProposed] = 0)"
> LABELITEM "ProjectNumber"
> CLASSITEM "PROJ_CURRENT_PHASE"
> NAME "LocalhProjectPolygons"
> TYPE POLYGON
> VALIDATION
> "PROJECTNUM" "[0-9]+"
> END
> FILTERITEM "ProjectNumber"
> FILTER "%PROJECTNUM%"
> CLASS
> NAME "05 Construction"
> EXPRESSION "05_Construction"
> TEXT "%PROJECTNUM%"
> LABEL
> MAXSCALEDENOM 28000
> FONT "vera_sans"
> SIZE 10
> ALIGN CENTER
> COLOR 255 0 0
> Thank you,
> -Scott
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20181128/3b6987d0/attachment-0001.html>
More information about the Geomoose-users
