[Geomoose-users] Toggle or Turn A Layer On or Off Programmatically from an Action or Service
Dan Little
theduckylittle at gmail.com
Sat Sep 1 05:25:54 PDT 2018
Try moving the dispatch to the query method. The Services don't expose the
full react-component cycle yet.
On Fri, Aug 31, 2018 at 11:21 AM Reynolds, Michael J. (MNIT) <
mike.reynolds at state.mn.us> wrote:
> I tucked that into a search service resultsAsHtml function but that
> resulted in the pesky
> Warning: Cannot update during an existing state transition (such as within
> `render` or another component's constructor). Render methods should be a
> pure function of props and state; constructor side-effects are an
> anti-pattern, but can be moved to `componentWillMount`.
> Do I use app.registerAction and app.startAction instead? Or should I use
> app.dispatch from some other service location?
> *From:* Dan Little [mailto:theduckylittle at gmail.com]
> *Sent:* Friday, August 31, 2018 10:22 AM
> *To:* Reynolds, Michael J. (MNIT) <mike.reynolds at state.mn.us>
> *Cc:* GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
> *Subject:* Re: [Geomoose-users] Toggle or Turn A Layer On or Off
> This is the ugly answer:
> app.dispatch({type: "MAPSOURCE_LAYER_VIS", mapSourceName: 'source',
> layerName: 'layer', on: true});
> We should write a wrapper function to make that easier.
> On Thu, Aug 30, 2018 at 9:02 AM Reynolds, Michael J. (MNIT) <
> Looking for the object and method that will toggle a layer visibility from
> an Action or Service.
> I didn't see examples within the docs or existing services/actions.
> On a related note, the geomoose search service, doesn't seem to turn on
> the layer being searched. It shows a results layer but along with it, we'd
> like to have the whole layer appear as reference. Do we have our search
> configured wrong?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20180901/b8771d6e/attachment.html>
More information about the Geomoose-users
