[Geomoose-users] GeoMoose 3.3 Map projection
James Klassen klassen.js at gmail.com
Fri Apr 19 18:45:01 PDT 2019
GeoMoose 3 is more or less tied to 3857 for the map.  I know there are
currently a few places where that is hard coded.  I don't know that it
necessarily needs to be that way, but it made some things simpler to
implement.
The services/maps/user controls can be reprojected on the fly.
On Fri, Apr 19, 2019, 20:23 Christopher Hughes <chughes at co.lincoln.or.us>
wrote:
> Can the map projection in GeoMoose 3.3 be configured? The coordinate
> display 'How-To' says that the xy coordinate default in the footer is the
> unprojected coordinate from the map, which will be whatever the map
> projection happens to be, but I haven't seen any documentation about how
> this could be changed to use a local coordinate system.
> Thanks!
> Chris
> Chris Hughes
> GIS Analyst
> Lincoln County Surveyor Department
> 880 NE 7th St. l Newport, OR 97365
> Tel: (541) 574 1283
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20190419/6d5e8b95/attachment.html>
More information about the Geomoose-users mailing list
