[Geomoose-users] GeoMOOSE Printing with SSL?
TC Haddad tchaddad at gmail.com
Tue Mar 12 13:04:39 PDT 2019
The MS4W php issue was related to not knowing where the certificate was. it
came up with Google geocoding in GM 2.x:
https://github.com/geomoose/geomoose/issues/167
If you think it is the same issue, you can set the location of your
certificate in the php.ini file of your MS4W install. I believe in later
versions of MS4W, Jeff fixed this issue (or at least there is a MS4W ticket
about it...
Tanya
On Tue, Mar 12, 2019 at 12:57 PM Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Jim,
> Thank you for your feedback.
> I did check that all the requests are https://.
> Also, I did update the server_name to geomoose.lyonco.org:443.  Should
> that be okay?
> How can I check if php does not like my certificate, and if needed make
> php trust the certificate?   And yes I am using MS4W which you said may
> cause issue.
> Thanks
> Sincerely,
> *Mark Volz, GISP*
> *Lyon County GIS Coordinator*
> *From:* James Klassen <klassen.js at gmail.com>
> *Sent:* Tuesday, March 12, 2019 12:37 PM
> *To:* Mark Volz <MarkVolz at co.lyon.mn.us>
> *Cc:* GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
> *Subject:* Re: [Geomoose-users] GeoMOOSE Printing with SSL?
> *SWHHS/LYON/LINCOLN COUNTY SECURITY NOTICE:*
> *This email originated from an external sender. Exercise caution before
> clicking on any links or attachments and consider whether you know the
> sender. For more information please contact IT support.*
> Some thoughts:
> Make sure all the requests in the browser are to https services.  http
> ones will likely be blocked in some contexts if the main page is http.  In
> any case you would get a mixed content warning.
> You need to use full domain names (whatever matches the ssl certificate)
> with https not ip adresses because ip addresses won't match the server
> certificate.
> You might also have an issue with the ssl certificate authority not being
> trusted by PHP (especially the PHP version included with some versions of
> MS4W). I remember seeing something about that awhile ago but I don't
> remember the details.
> On Tue, Mar 12, 2019, 10:03 Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> After updating my server to SSL I am having issues printing maps in
> GeoMOOSE 2.9.3.  At this point in time I can get GeoMOOSE to present a map
> to the end user and display the background.  However, I cannot see any
> active layers such as parcels.   Please let me know if anyone has a thought
> as to why the active layers are not printing.
> Thanks
> P.S.  Originally I could not get anything to work on the client side after
> switching to SSL.  On the client side the Print Map displays “Loading…”
> forever.  On the server side a PDF is generated in the temp folder, however
> only the template and background map display and the active layers such as
> parcels do not display.  I changed server_name to use my ip address and
> port 443 so now my end users can see the pdf template and background, but
> still not the parcel layer.  As of right now the background layer will
> work in both http and https mode.
> Sincerely,
> *Mark Volz, GISP*
> 504 Fairgrounds Rd
> <https://linkprotect.cudasvc.com/url?a=https%3a%2f%2fwww.google.com%2fmaps%2f%3fdaddr%3d504%2520Fairgrounds%2520Rd%2c%2520Marshall%2c%2520MN%252056258%3fz%3d6&c=E,1,mTQU2ON9bb_CVbDyOLsQN45Ad_qKRqMb9ACvXsviPg7KhQzOkcK5ZhokS5-Pkl5Bnr4U6uPs_ooih20JlUnhs5_OP6ZLU0YBhW2AlQebZWvuH23k&typo=1>
> Marshall, MN 56258
> <https://linkprotect.cudasvc.com/url?a=https%3a%2f%2fwww.google.com%2fmaps%2f%3fdaddr%3d504%2520Fairgrounds%2520Rd%2c%2520Marshall%2c%2520MN%252056258%3fz%3d6&c=E,1,ILeg6P_P9-xPMxha_q3NUqoPP3v-wKwKziZ6zeIqDq4T7EUMjQo7fSnFk6mDG0v1cRWkdftL4TxcToFUC8Qh-DBkD5-Ik9X8otzuagfgsg5CgtI-RSl64xgpqT9S&typo=1>
> Ph:  (507) 532-8218
> Fax: (507) 532-8217
> http://lyonco.org/
> <https://linkprotect.cudasvc.com/url?a=http%3a%2f%2flyonco.org%2f&c=E,1,q3lHUmLn5wM3BeiKv6cd8VmSxvoGvRnCS6wIKkmkl7-tn7RZAl_X_HDHACZIaTfrCjwwsxmBhD2hRR_vPyjb3BI5X4qZeIM9bn9bUlklh1ODjBk,&typo=1>
> http://geomoose.lyonco.org/
> <https://linkprotect.cudasvc.com/url?a=http%3a%2f%2fgeomoose.lyonco.org%2f&c=E,1,kx97pZJ7xI0XBJpPZ46tFr4Sbvyfwi5KG9pv9GwoA6nQd9xbQDx1Ux_cAwKiGVvQ_m0wM7cMERB9tBc68RJreUQkRR40Jn3p2ovcxO_mWf0,&typo=1>
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
> <https://linkprotect.cudasvc.com/url?a=https%3a%2f%2flists.osgeo.org%2fmailman%2flistinfo%2fgeomoose-users&c=E,1,7NU89jo82JmJocFfkt3wzJ7URLYdK5TXdhIBg2997LMGcDTNt4GVK8n6YkxeUX6cIQkMqbxesQScSRhSa6iB4rcAeVChI3UI07kU8Nd1bQt3MEpZRcU,&typo=1>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20190312/2eb6298d/attachment-0001.html>
More information about the Geomoose-users mailing list
