[Geomoose-users] GeoMOOSE Printing with SSL?
James Klassen
klassen.js at gmail.com
Tue Mar 12 13:33:49 PDT 2019
Ah good, someone who knows what they are talking about already answered it.
On Tue, Mar 12, 2019, 15:31 James Klassen <klassen.js at gmail.com> wrote:
> Based on chasing the links in previous list traffic it looks like two
> lines need to be changed in php.ini. I have only run ms4w locally though
> for testing so I haven't run into this issue myself.
> https://ms4w.com/trac/ticket/171
> On Tue, Mar 12, 2019, 14:57 Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
>> Jim,
>> Thank you for your feedback.
>> I did check that all the requests are https://.
>> Also, I did update the server_name to geomoose.lyonco.org:443. Should
>> that be okay?
>> How can I check if php does not like my certificate, and if needed make
>> php trust the certificate? And yes I am using MS4W which you said may
>> cause issue.
>> Thanks
>> Sincerely,
>> *Mark Volz, GISP*
>> *Lyon County GIS Coordinator*
>> *From:* James Klassen <klassen.js at gmail.com>
>> *Sent:* Tuesday, March 12, 2019 12:37 PM
>> *To:* Mark Volz <MarkVolz at co.lyon.mn.us>
>> *Cc:* GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
>> *Subject:* Re: [Geomoose-users] GeoMOOSE Printing with SSL?
>> *SWHHS/LYON/LINCOLN COUNTY SECURITY NOTICE:*
>> *This email originated from an external sender. Exercise caution before
>> clicking on any links or attachments and consider whether you know the
>> sender. For more information please contact IT support.*
>> Some thoughts:
>> Make sure all the requests in the browser are to https services. http
>> ones will likely be blocked in some contexts if the main page is http. In
>> any case you would get a mixed content warning.
>> You need to use full domain names (whatever matches the ssl certificate)
>> with https not ip adresses because ip addresses won't match the server
>> certificate.
>> You might also have an issue with the ssl certificate authority not being
>> trusted by PHP (especially the PHP version included with some versions of
>> MS4W). I remember seeing something about that awhile ago but I don't
>> remember the details.
>> On Tue, Mar 12, 2019, 10:03 Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
>> Hello,
>> After updating my server to SSL I am having issues printing maps in
>> GeoMOOSE 2.9.3. At this point in time I can get GeoMOOSE to present a map
>> to the end user and display the background. However, I cannot see any
>> active layers such as parcels. Please let me know if anyone has a thought
>> as to why the active layers are not printing.
>> Thanks
>> P.S. Originally I could not get anything to work on the client side
>> after switching to SSL. On the client side the Print Map displays
>> “Loading…” forever. On the server side a PDF is generated in the temp
>> folder, however only the template and background map display and the active
>> layers such as parcels do not display. I changed server_name to use my ip
>> address and port 443 so now my end users can see the pdf template and
>> background, but still not the parcel layer. As of right now the
>> background layer will work in both http and https mode.
>> Sincerely,
>> *Mark Volz, GISP*
>> 504 Fairgrounds Rd
>> <https://linkprotect.cudasvc.com/url?a=https%3a%2f%2fwww.google.com%2fmaps%2f%3fdaddr%3d504%2520Fairgrounds%2520Rd%2c%2520Marshall%2c%2520MN%252056258%3fz%3d6&c=E,1,mTQU2ON9bb_CVbDyOLsQN45Ad_qKRqMb9ACvXsviPg7KhQzOkcK5ZhokS5-Pkl5Bnr4U6uPs_ooih20JlUnhs5_OP6ZLU0YBhW2AlQebZWvuH23k&typo=1>
>> Marshall, MN 56258
>> <https://linkprotect.cudasvc.com/url?a=https%3a%2f%2fwww.google.com%2fmaps%2f%3fdaddr%3d504%2520Fairgrounds%2520Rd%2c%2520Marshall%2c%2520MN%252056258%3fz%3d6&c=E,1,ILeg6P_P9-xPMxha_q3NUqoPP3v-wKwKziZ6zeIqDq4T7EUMjQo7fSnFk6mDG0v1cRWkdftL4TxcToFUC8Qh-DBkD5-Ik9X8otzuagfgsg5CgtI-RSl64xgpqT9S&typo=1>
>> Ph: (507) 532-8218
>> Fax: (507) 532-8217
>> http://lyonco.org/
>> <https://linkprotect.cudasvc.com/url?a=http%3a%2f%2flyonco.org%2f&c=E,1,q3lHUmLn5wM3BeiKv6cd8VmSxvoGvRnCS6wIKkmkl7-tn7RZAl_X_HDHACZIaTfrCjwwsxmBhD2hRR_vPyjb3BI5X4qZeIM9bn9bUlklh1ODjBk,&typo=1>
>> http://geomoose.lyonco.org/
>> <https://linkprotect.cudasvc.com/url?a=http%3a%2f%2fgeomoose.lyonco.org%2f&c=E,1,kx97pZJ7xI0XBJpPZ46tFr4Sbvyfwi5KG9pv9GwoA6nQd9xbQDx1Ux_cAwKiGVvQ_m0wM7cMERB9tBc68RJreUQkRR40Jn3p2ovcxO_mWf0,&typo=1>
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
>> <https://linkprotect.cudasvc.com/url?a=https%3a%2f%2flists.osgeo.org%2fmailman%2flistinfo%2fgeomoose-users&c=E,1,7NU89jo82JmJocFfkt3wzJ7URLYdK5TXdhIBg2997LMGcDTNt4GVK8n6YkxeUX6cIQkMqbxesQScSRhSa6iB4rcAeVChI3UI07kU8Nd1bQt3MEpZRcU,&typo=1>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20190312/24b091a5/attachment.html>
More information about the Geomoose-users
