[Geomoose-users] Converting from ags to raster map file
Colas, Scott Scott.Colas at ct.gov
Wed Mar 13 06:05:11 PDT 2019
Hi James,
Thank you for your response. What do you think I should change my CONNECTIONTYPE to? .
Also my goal is to combine two layers in one map file and make each layer visible at different zoom levels using MAXSCALEDENOM AND MINSCALEDENOM. Is it possible to accomplish this only using the mapbook?
MAP
       INCLUDE "../../geomoose_globals.map"
       WEB
              INCLUDE "../../temp_directory.map"
              LOG "mapserver.log"
              METADATA
                     "ows_title" "UCONN 2016 Ortho Imagery"
                     "ows_srs" "EPSG:3857"
                     "ows_enable_request" "*"
              END
       END
       PROJECTION
              "init=epsg:3857"
       END
       LAYER
              NAME "layer1"
              CONNECTION "http://services.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer/WMTS/1.0.0/WMTSCapabilities.xml"
              CONNECTIONTYPE WMS
              TYPE RASTER
              CLASS
                           MAXSCALEDENOM 13000
              END
              METADATA
                     "wms_srs" "EPSG:3857"
                     "wms_name" "Imagery"
                     "wms_server_version" "1.1.1"
                     "wms_format" "image/jpeg"
              END
       END
       LAYER
              NAME "layer2"
              CONNECTION "http://wms.onterrasystems.com/WMSService.svc/a48a7531547e4367b28a96ab03507fd4/WMSLatLon"
              CONNECTIONTYPE WMS
              TYPE RASTER
              CLASS
                           MINSCALEDENOM 13001
              END
              METADATA
                     "wms_name" "OnTerraWMS"
                     "wms_style" "Road"
              END
       END
END’
Thank you,
Scott
From: James Klassen [mailto:klassen.js at gmail.com]
Sent: Tuesday, March 12, 2019 4:37 PM
To: Colas, Scott
Cc: GeoMOOSE Users List
Subject: Re: [Geomoose-users] Converting from ags to raster map file
I'm going to guess here that CONNECTIONTYPE WMS in the mapfile isn't correct for an ArcGIS REST endpoint.
On Tue, Mar 12, 2019, 13:57 Colas, Scott <Scott.Colas at ct.gov<mailto:Scott.Colas at ct.gov>> wrote:
Hello All,
I am having trouble converting a ags map into a raster map file. I took the URL from the old map source and put it inside of a layer but it’s not loading.
Old source: Working
  <map-source name="agsimagery" type="ags" reference="false" opacity=".3">
    <url>http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer/export</url>
    <layer name="Imagery" reference="false" />
    <param name="FORMAT" value="png"/>
  </map-source>
New source and layer: Not working
  <map-source name="uconnOrtho2012" type="mapserver" >
    <file>./ct/wms/uconnOrtho2012.map</file>
    <layer name="Imagery" />
  </map-source>
MAP
       WEB
              METADATA
                     'ows_title' 'UCONN 2012 Ortho imagery'
                     'ows_srs' 'EPSG:3857'
                     'ows_enable_request' '*'
              END
       END
       PROJECTION
              "init=epsg:3857"
       END
       LAYER
              STATUS ON
              NAME "Imagery"
              CONNECTION "http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer/export"
              CONNECTIONTYPE WMS
              TYPE RASTER
              METADATA
                     "wms_enable_request" "*"
                     "wms_format" "image/png"
              END
       END
END
Thank you
-Scott
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20190313/62ea39df/attachment-0001.html>
More information about the Geomoose-users mailing list
