[Geomoose-users] Converting from ags to raster map file
Dan Little theduckylittle at gmail.com
Sat Mar 30 10:14:34 PDT 2019
You could also check that the end point outputs a real WMS server.
"/export" does not do that.
On Wed, Mar 13, 2019 at 1:33 PM James Klassen <klassen.js at gmail.com> wrote:
> Off the top of my head, you will need to create a GDAL vrt file that points to the AGS service and then point the mapfile at the vrt file.
> Sorry, I don't have time to look up the details today.
> On Wed, Mar 13, 2019, 08:05 Colas, Scott <Scott.Colas at ct.gov> wrote:
>> Hi James,
>> Thank you for your response. What do you think I should change my CONNECTIONTYPE to? .
>> Also my goal is to combine two layers in one map file and make each layer visible at different zoom levels using MAXSCALEDENOM AND MINSCALEDENOM. Is it possible to accomplish this only using the mapbook?
>> MAP
>>        INCLUDE "../../geomoose_globals.map"
>>        WEB
>>               INCLUDE "../../temp_directory.map"
>>               LOG "mapserver.log"
>>               METADATA
>>                      "ows_title" "UCONN 2016 Ortho Imagery"
>>                      "ows_srs" "EPSG:3857"
>>                      "ows_enable_request" "*"
>>               END
>>        END
>>        PROJECTION
>>               "init=epsg:3857"
>>        END
>>        LAYER
>>               NAME "layer1"
>>               CONNECTION "http://services.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer/WMTS/1.0.0/WMTSCapabilities.xml"
>>               CONNECTIONTYPE WMS
>>               TYPE RASTER
>>               CLASS
>>                            MAXSCALEDENOM 13000
>>               END
>>               METADATA
>>                      "wms_srs" "EPSG:3857"
>>                      "wms_name" "Imagery"
>>                      "wms_server_version" "1.1.1"
>>                      "wms_format" "image/jpeg"
>>               END
>>        END
>>        LAYER
>>               NAME "layer2"
>>               CONNECTION "http://wms.onterrasystems.com/WMSService.svc/a48a7531547e4367b28a96ab03507fd4/WMSLatLon"
>>               CONNECTIONTYPE WMS
>>               TYPE RASTER
>>               CLASS
>>                            MINSCALEDENOM 13001
>>               END
>>               METADATA
>>                      "wms_name" "OnTerraWMS"
>>                      "wms_style" "Road"
>>               END
>>        END
>> END’
>> Thank you,
>> Scott
>> From: James Klassen [mailto:klassen.js at gmail.com]
>> Sent: Tuesday, March 12, 2019 4:37 PM
>> To: Colas, Scott
>> Cc: GeoMOOSE Users List
>> Subject: Re: [Geomoose-users] Converting from ags to raster map file
>> I'm going to guess here that CONNECTIONTYPE WMS in the mapfile isn't correct for an ArcGIS REST endpoint.
>> On Tue, Mar 12, 2019, 13:57 Colas, Scott <Scott.Colas at ct.gov> wrote:
>> Hello All,
>> I am having trouble converting a ags map into a raster map file. I took the URL from the old map source and put it inside of a layer but it’s not loading.
>> Old source: Working
>>   <map-source name="agsimagery" type="ags" reference="false" opacity=".3">
>>     <url>http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer/export</url>
>>     <layer name="Imagery" reference="false" />
>>     <param name="FORMAT" value="png"/>
>>   </map-source>
>> New source and layer: Not working
>>   <map-source name="uconnOrtho2012" type="mapserver" >
>>     <file>./ct/wms/uconnOrtho2012.map</file>
>>     <layer name="Imagery" />
>>   </map-source>
>> MAP
>>        WEB
>>               METADATA
>>                      'ows_title' 'UCONN 2012 Ortho imagery'
>>                      'ows_srs' 'EPSG:3857'
>>                      'ows_enable_request' '*'
>>               END
>>        END
>>        PROJECTION
>>               "init=epsg:3857"
>>        END
>>        LAYER
>>               STATUS ON
>>               NAME "Imagery"
>>               CONNECTION "http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer/export"
>>               CONNECTIONTYPE WMS
>>               TYPE RASTER
>>               METADATA
>>                      "wms_enable_request" "*"
>>                      "wms_format" "image/png"
>>               END
>>        END
>> END
>> Thank you
>> -Scott
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
