[Geomoose-users] switch layer at a particular zoom level?
Christopher Hughes
chughes at co.lincoln.or.us
Thu Oct 24 08:30:28 PDT 2019
You can set scales in the MAPFILE for a particular layer. See a contours
example below (pardon the formatting).
We have a separate 10ft contours data set with MINSCALE 0 and MAXSCALE 1000
so one turns on when the other turns off:
LAYER
NAME "Contours"
DATA "./lincdata/elev40"
STATUS on
MINSCALE 1000
MAXSCALE 8000
TYPE LINE
LABELITEM "contour"
CLASS
NAME "40 Foot Contours"
STYLE
pattern 40 6 6 6 6 end
width 1
COLOR 190 190 190
END
LABEL
TYPE TrueType
FONT "arial"
SIZE 8.25
COLOR 170 170 170
OUTLINEWIDTH 1
POSITION auto
PARTIALS false
BUFFER 1
ANGLE auto
END
END
END
Best,
Chris Hughes
GIS Analyst
Lincoln County
On Thu, Oct 24, 2019 at 8:22 AM Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> Is it possible to have GeoMOOSE 2.x switch between two sources at a
> particular zoom level? As a user zooms into the map, I would like to
> switch between a political map and an air photo map. Unfortunatly I am not
> sure which tags I should use to do this, and where I should add the tags.
> My best guess is that I will need to add the max and min scales at the map
> source level, but please correct me if I am wrong.
> For example can we set the scale at the map source level?
> <map-source name="StandardBackgroundWMS" type="wms" reference="false"
> tiled="true" width="256" height="256" buffer="false"
> transition_Effect="resize" maxscale = 50000>
> <map-source name=”PoliticalMapWMS” type="wms" reference="false"
> transition_Effect="resize" minscale = 50001>
> <layer title="Standard Background" src="PoliticalMapWMS/PoliticalMap:
> WMSServer/AirPhotoBackground " status="on" legend="false"
> show-legend="false" identify="false"/>
> Thanks!
> Sincerely,
> *Mark Volz, GISP*
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
Chris Hughes
GIS Analyst
Lincoln County Surveyor Department
880 NE 7th St. l Newport, OR 97365
Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20191024/a60df27b/attachment.html>
More information about the Geomoose-users
