[Geomoose-users] GeoMoose 3 - Speed
Christopher Hughes chughes at co.lincoln.or.us
Mon Feb 3 08:18:19 PST 2020
I'm using an older version of mapserver on this server for geomoose 2
(which is the one rendering faster).
I am reprojecting to our local coordinate system which I didn't have to do
for geomoose 2. Perhaps I have my extent coordinates wrong.
Chris
On Sun, Feb 2, 2020 at 10:54 AM Brian Fischer <bfischer at houstoneng.com>
wrote:
> Chris,
> Are you using the same MS4W version for both applications?  If not see
> what MapServer version each is using and check to make sure you have
> indexes built for both on the data source.
> Brian
>   *Brian Fischer *
> {Title}
> Houston Engineering, Inc.
> *O* 763.493.4522 | *D* 763.493.6664 | *C *763.229.2734
>    7550 Meridian Circle North, Suite 120
> Maple Grove, MN • 55369
> *www.houstoneng.com* <http://www.houstoneng.com/>
> Follow us: Facebook <https://www.facebook.com/houstoneng> | Twitter
> <https://twitter.com/houstoneng> | LinkedIn
> <https://www.linkedin.com/company/houston-engineering-inc.> | YouTube
> <https://www.youtube.com/user/HoustonEngInc>
> This entire message (including all forwards and replies) and any
> attachments are for the sole use of the intended recipient(s) and may
> contain proprietary, confidential, trade secret, work-product,
> attorney-client or privileged information. Any unauthorized review, use,
> disclosure or distribution is prohibited and may be a violation of law. If
> you are not the intended recipient, please contact the sender by reply
> email and destroy all copies of the original message.
> *From:* Geomoose-users <geomoose-users-bounces at lists.osgeo.org> *On
> Behalf Of *Dan Little
> *Sent:* Sunday, February 2, 2020 12:12 PM
> *To:* TC Haddad <tchaddad at gmail.com>
> *Cc:* geomoose-users at mail.osgeo.org
> *Subject:* Re: [Geomoose-users] GeoMoose 3 - Speed
> *[External Email]*
> I was going to suggest tracking down the issues with the mapfile. We
> actually did some initial benchmarking in GM2 vs GM3 development and there
> are a lot of code paths that actually ended up faster. But I do admit
> sometimes the data transfer + parsing can make a service call feel less
> responsive.
> On Fri, Jan 31, 2020 at 7:47 PM TC Haddad <tchaddad at gmail.com> wrote:
> Is there a reprojection happening in your 3.x setup that wasn't happening
> in your 2.x setup?
> On Sat, Feb 1, 2020 at 1:56 AM Christopher Hughes <
> chughes at co.lincoln.or.us> wrote:
> I'm using WMS for display and WFS for queries. The surveys dataset I
> mentioned is connecting to a postgis server,
> whereas the rest of my data are in shapefiles on the same server. Looking
> at shp2img it looks like it's in the drawing
> of the layer rather than in the web service.
> Shp2img results:
> -msDrawMap(): Layer 0 (Surveys), 0.043s             -    using mapfile
> from geomoose 2
> -msDrawMap(): Layer 0 (Surveys), 7.219s             -    using mapfile
> from geomoose 3
> Although that kind of points to my mapfile configuration. I'll continue
> debugging.
> Chris
> On Fri, Jan 31, 2020 at 3:36 PM James Klassen <klassen.js at gmail.com>
> wrote:
> How are you loading the data in GeoMoose 3?  In GeoMoose 2 I'm guessing it
> was via WMS.
> Where are you seeing the bottleneck?  The web service or inside GeoMoose
> proper?
> Generally speaking...
> If you are using WMS then load times should be similar.
> If you are using WFS it might be faster or slower on initial load
> depending on the amount of vector data transfered.  I think GeoMoose will
> pass a bounding box to the WFS server so if you zoom in first it might
> help.  It should be faster than GeoMoose 2 on interactions after initial
> data load.
> GeoMoose 3 also supports using a WMS layer for display but a WFS later for
> query.  That might help the initial load times.
> On Fri, Jan 31, 2020, 15:27 Christopher Hughes <chughes at co.lincoln.or.us>
> wrote:
> Does anyone have any advice on how to improve data rendering speeds for
> GeoMoose 3?
> I'm having some issues loading vector data quickly, although our imagery
> does also load a
> bit slower than in our GeoMoose 2 website. I'm on Windows but it doesn't
> appear to be
> inherently a Windows vs Linux issue. I can load our surveys dataset with
> GeoMoose 2
> in around 2 seconds, but when I switch to GeoMoose 3, the same dataset on
> the same server
> takes around 10 seconds to load.
> I've noticed that the services run very quickly. I can search or select
> data about as quickly
> as on GeoMoose 2, but when it comes to then zooming to results and
> rendering the data
> there's a significant lag, even when comparing GeoMoose 2 and 3 when on
> the same Windows
> server.
> Thanks for any suggestions,
> Chris
> Chris Hughes
> GIS Analyst
> Lincoln County Surveyor Department
> 880 NE 7th St. l Newport, OR 97365
> Tel: (541) 574 1283
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
> Chris Hughes
> GIS Analyst
> Tel: (541) 574 1283
Chris Hughes
GIS Analyst
Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200203/b5018a1a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200203/b5018a1a/attachment-0001.png>
More information about the Geomoose-users mailing list
