[Geomoose-users] Serving ECW Images
Dan Little
theduckylittle at gmail.com
Fri Feb 7 19:23:02 PST 2020
Thanks Jeff!
On Tue, Feb 4, 2020 at 8:08 AM Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> I added a step in the documentation (see Step2 at
> https://ms4w.com/README_INSTALL.html#ecw )
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> https://gatewaygeomatics.com/
> On 2020-02-04 8:16 a.m., Jeff McKenna wrote:
> > Hi Lara,
> > Since you are using MS4W you can follow the steps for ECW support at
> > https://ms4w.com/README_INSTALL.html#ecw (you also have that document
> > locally in your /ms4w root) Here are those steps, below:
> > Steps to Enable ECW Support in MS4W
> > Step 1
> > For access to ECW files through the GDAL library in MS4W, move the
> > gdal_ECW_JP2ECW.dll plugin file up from /ms4w/gdalplugins/ecw/ into
> > /ms4w/gdalplugins/
> > If this is successful, executing the following at the commandline (after
> > setting /ms4w/setenv.bat) “gdalinfo –formats” should list the “ECW” and
> > “JP2ECW” drivers.
> > ECW -raster- (rw): ERDAS Compressed Wavelets (SDK 3.x)
> > JP2ECW -raster,vector- (rw+v): ERDAS JPEG2000 (SDK 3.x)
> > Step 2
> > For display in MapServer, after moving the plugin, follow the regular
> > Raster Data document (https://mapserver.org/input/raster.html). Here is
> > an example mapfile configuration:
> > LAYER
> > NAME "ecw"
> > TYPE RASTER
> > STATUS ON
> > DATA "00203065F09.ecw"
> > CLASS
> > NAME "ECW test"
> > END
> > END
> > Thank you for using MS4W.
> > "MS4W: open doors as well as windows"
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200207/eb037b1b/attachment.html>
More information about the Geomoose-users
