[Geomoose-users] Geomoose and Database
Eli Adam eadam at co.lincoln.or.us
Mon Feb 24 08:17:04 PST 2020
On Mon, Feb 24, 2020 at 6:31 AM James Klassen <klassen.js at gmail.com> wrote:
> Your question is very vague about what you are trying to accomplish, so I can only give a very general response.
> GeoMoose (or anything running in a web browser) cannot talk to PostgreSQL directly.  You need some middleware on the web server to bridge the two.  That could be anything from MapServer/GeoServer or a simple perl/php/python/ruby/nodejs script to a full fledged framework.
Following on Jim's general response, this is the typical scenario of
displaying vector data from Postgresql/PostGIS using MapServer,
https://www.mapserver.org/input/vector/postgis.html  That is how we
display our vector PostGIS data in GeoMoose.
Best regards, Eli
> What makes the most sense depends on what you are trying to do and what tools you are comfortable with.
> If you give us a better idea of what you are trying to achieve and what environment and tools you have available, we can likely provide you with better suggestions.
> On Mon, Feb 24, 2020, 02:10 Jul.Ivars . <julien.ivars at outlook.com> wrote:
>> Hello !
>> I’m using Geomoose for a project and I want to connect a Database (Postgres) to geomoose … but I don’t know how to …
>> I’ve try some things like npm « pg » but it didn’t work and I don’t know at all how to do … Did I have to did it like, using ‘pg’ to connect and after put all my connection into the index.js ? Or I am totally wrong ?
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
