[Geomoose-users] GeoMoose 3 - Select
Dan Little
theduckylittle at gmail.com
Sun Jan 26 13:24:19 PST 2020
This should be settable in app.js:
app.registerService('my-other-select', SelectService, {
// remove the layer select
inputs: [{
type: 'hidden',
default: 'source/layer'
This change removes the Select input and makes it a fixed field. You can
also specify that as a select with a fixed list of layers.
On Fri, Jan 10, 2020 at 3:35 PM Christopher Hughes <chughes at co.lincoln.or.us>
wrote:
> For geomoose 3, is there a way to specify which layers you can select
> rather than just setting
> the default layer and being able to select all layers you've set to be
> selectable? I'd like to create
> a select tool for each of the layers I want to select (like you can for
> searches), but if I do that now
> you'd still be able to switch to a different layer in the tool. Relatedly,
> is there a way to remove the
> 'Select from' dropdown box so it just uses the default layer you set in
> the service?
> Thanks,
> Chris
> Chris Hughes
> GIS Analyst
> Lincoln County Surveyor Department
> 880 NE 7th St. l Newport, OR 97365
> Tel: (541) 574 1283
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200126/a8161e06/attachment.html>
More information about the Geomoose-users
