[Geomoose-users] GeoMoose 3 - Speed
TC Haddad
tchaddad at gmail.com
Fri Jan 31 17:46:50 PST 2020
Is there a reprojection happening in your 3.x setup that wasn't happening
in your 2.x setup?
On Sat, Feb 1, 2020 at 1:56 AM Christopher Hughes <chughes at co.lincoln.or.us>
wrote:
> I'm using WMS for display and WFS for queries. The surveys dataset I
> mentioned is connecting to a postgis server,
> whereas the rest of my data are in shapefiles on the same server. Looking
> at shp2img it looks like it's in the drawing
> of the layer rather than in the web service.
> Shp2img results:
> -msDrawMap(): Layer 0 (Surveys), 0.043s - using mapfile
> from geomoose 2
> -msDrawMap(): Layer 0 (Surveys), 7.219s - using mapfile
> from geomoose 3
> Although that kind of points to my mapfile configuration. I'll continue
> debugging.
> Chris
> On Fri, Jan 31, 2020 at 3:36 PM James Klassen <klassen.js at gmail.com>
> wrote:
>> How are you loading the data in GeoMoose 3? In GeoMoose 2 I'm guessing
>> it was via WMS.
>> Where are you seeing the bottleneck? The web service or inside GeoMoose
>> proper?
>> Generally speaking...
>> If you are using WMS then load times should be similar.
>> If you are using WFS it might be faster or slower on initial load
>> depending on the amount of vector data transfered. I think GeoMoose will
>> pass a bounding box to the WFS server so if you zoom in first it might
>> help. It should be faster than GeoMoose 2 on interactions after initial
>> data load.
>> GeoMoose 3 also supports using a WMS layer for display but a WFS later
>> for query. That might help the initial load times.
>> On Fri, Jan 31, 2020, 15:27 Christopher Hughes <chughes at co.lincoln.or.us>
>> wrote:
>>> Does anyone have any advice on how to improve data rendering speeds for
>>> GeoMoose 3?
>>> I'm having some issues loading vector data quickly, although our imagery
>>> does also load a
>>> bit slower than in our GeoMoose 2 website. I'm on Windows but it doesn't
>>> appear to be
>>> inherently a Windows vs Linux issue. I can load our surveys dataset with
>>> GeoMoose 2
>>> in around 2 seconds, but when I switch to GeoMoose 3, the same dataset
>>> on the same server
>>> takes around 10 seconds to load.
>>> I've noticed that the services run very quickly. I can search or select
>>> data about as quickly
>>> as on GeoMoose 2, but when it comes to then zooming to results and
>>> rendering the data
>>> there's a significant lag, even when comparing GeoMoose 2 and 3 when on
>>> the same Windows
>>> server.
>>> Thanks for any suggestions,
>>> Chris
>>> Chris Hughes
>>> GIS Analyst
>>> Lincoln County Surveyor Department
>>> 880 NE 7th St. l Newport, OR 97365
>>> Tel: (541) 574 1283
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
> Chris Hughes
> GIS Analyst
> Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200201/efc4d21d/attachment-0001.html>
More information about the Geomoose-users
